It’s a shame the sister light only measured 2A at the emitter so about 2,000 lumen and not the rated 2700 listed on Banggoods website.
Also not 1697 meters. Maybe 1400m?
Still, this is pretty good for the price. I kind of knew those extreme specs were not going to be met.
Does anyone think the Astrolux version will be better than the Mateminco version?
I think the goal is to move the reflector surface as far away from the light source as possible which effectively makes the emitter size smaller and you end up with better reflecting angles for a more concentrated beam/less corona.
Might not be the GT, but i am sure this will still scare most normal people.
I am myself bypassing the GT as it is too much of a good thing.
Hell the U21 of mine scared a couple of cops that’s used to much less from their similar sized torch costing 4 X more ( assuming that prize as government spending taxpayer money never seem to be done by due diligence )
I will not be the one complaining if the “light-saber” part get a 1 up its the only means of self defense for us little Danes.
If you say here you are interested, you will be added to the list. Then when the light comes out Freeme will send you his special coupon code that will lower the price more than the pre-order price. Plus he will help you if you have any warranty issues.
It’s possible the Astrolux version might be different, like higher output from the emitter, but we can’t say for sure until it comes out and is tested.
Do you know somebody, how many Ampers it will take from batteries? I have good choice to buy Samsung batteries INR18650-35E, with capacity 3500 mAh, with constant discharge current 8 A and 13 A peak. It is 500 mAh more capacity as recomended. Samsung 30Q, but less peak discharge current. Will it be enough? Somewhere I read, that the light will take only 4 Ampers.
If the emitter is only going to put out 2A at 12v with the 2S2P battery carrier, plus using a boost driver then each of the 4 cells might see 2.5A (2A plus a bit extra for driver efficiency). With only 2 cells in the carrier, the load will be about 5A each max.
There is no need for high drain cells on this light.
