When you take a picture like that measuring the reflector diameter, line up the camera directly overhead of the one edge where the measurement is. Don’t put the camera in the middle.
Put your eye over the 0 end of the ruler to line it up, then put your eye over the other end and you’ll get very close measurements. Always look at perfect right angles, 90°.
Yes, I was being lazy and used my tablet. Should hopefully get some nice beamshots with my DSLR later on when I walk my dog - obviously I’ll have my tripod with me then
EDIT: Someone else will have to measure the current draw. Just tried with my cheap DMM on the 10A setting, and the display just showed ‘1’ before the contacts got so hot that I had to let go!
I think Lexel had to run a special wire loop out of the back of the carrier to use his clamp meter to measure the amp draw on the MF01. So I really don’t know of any easy way to measure it. No worries, though. Thanks for trying.
Got mine too. It’s CW, but not as cool as they specify. Mine is about 5800K on low.
Runtime tests underway. Doesn’t heat up very fast, steps down at 7 minutes on turbo at about 50°C surface temp. Makes that annoying clicking sound from the heat expansion.
Nice, are you planning to review it? I think most folks just want to know if it comes close to the listed specs or if it performs just like the Mateminco MT35.
And unfortunately my light didn’t come with the screw-in tripod thing, like the MF-01 did. Is it possible to get that, or is it a standard component that I can get anywhere?
Nothing there - the only items in the little bag were the attachment for the sling, the sling / shoulder strap itself, and a spare o-ring. But no tripod connector.
Got a track # for mine, seem to have been shipped with DHL singapore, but that’s also all the number give me so inclined to think its actually just shipped today
all track # say are 2017-12-08 09:16 SINGAPORE-SGP, Shipment information received
Sadly this mean i will get fleeced as that’s the norm with DHL, so i fear the flashlight will end up costing me a additional 25 USD at the least
I just went to take more beamshots (which somehow all turned out blurred), and unfortunately now the light can no longer be turned off without twisting the tailcap. A long press only activates a slightly-lower-than-low mode.
When I unscrewed the tail cap to take out the batteries, one of the small discs (the + contact) dropped out, and it looks like it had become unscrewed from the carrier. I tightened the screws on both ends, but it’s still not working properly, and sometimes the light refuses to come out of low mode at all. I also tried it with the battery carrier (and batteries) from the MF-01, but with the same result.
Unfortunately, one of the clips of the shoulder strap has broken, as well…
