Has anyone been able to measure the emitter star size? I’m learning these big reflector lights tend to need a star bigger than the normal 20mm which can cause some difficulty finding them.
Hi Rusty
Out of curiosity do you have a link to where you got the mateminco ?
I’ve got a code for the MF02 but I’m waiting in the wings for a few to surface before I pounce on one
Thanks mate
I did this shot tonight, and i got to say while its far off i swear it looked to me like the chimny at the Verdo power plant bacame more easy to see.
Chimney in middle of pic visible over rooftops, this vantage point are some + 50 - 60 M above the water.
I am looking high and low for a darker place to do a shot, after all my little home town do have a little light pollution going on too.
But no doubt this sucker reach farther than anything i have, and i am pretty happy with it, even if it became more expensive than i hoped it will be due to the silly circumstances here.
That’s promising. I don’t know what the efficiency of the boost driver is, but let’s say 90%. If the batteries are fully charged, then that should deliver about 2.7A to the emitter.
Even at 80% efficiency it would deliver 2.4A to the emitter.
Boost drivers are a bit tricky to guess at, but I think my numbers are correct. It definitely seems like more power to the emitter than the older MT35 driver which tested at 1.9A
Let me see if i can get a couple of gut shots to work.
Removing the thermal paste and then putting it back together resulted in a light not working, i had to put a spacer in the rear to get it going again.
I have not been able to unscrew the business end, its simply too tight for my old hands to grip it good enough, and i dont have any pliers that can grip on such a large diameter.
Yeah its really weird, at first i was like Nooooo i broke it :person_facepalming:
But then with the tail cap off i pressed down on the battery carrier with the hand and then the light worked just fine, i am going thru moving boxes that have been standing here in my apartment for 6 years unopened cuz i know i have some little brass shims that will be fine.
Also frustrating i cant unscrew the glass and get it opened in that end, i really wanted to have a look in there too.
