Dimensions are as follows:
DEPTH 15 mm
HEIGHT 94 mm
WIDTH 26 mm
BLADE LENGTH 71 mm
PRODUCT WEIGHT 69 g
Price: 8$
The most attractive feature of the knife are the decorative ridges that the liners have. They look unremarkable in the photos but they have a pleasing tendency to catch the light and sparkle giving the whole knife a somewhat jeweled appearance. The blade is well ground, nicely polished and easy to sharpen. It cuts about as well as you’d expect for a hollow ground blade of this thickness. The pocket clip is tight and polished well, so it adds somewhat to the appearance of the knife. The lockup is at 40% and does its job neither giving in to spine pressure or whacking (don’t do this to your knives).
So the good:
+good value for money, 8cr13mov is really decent steel, easy to sharpen and does the job quite well
+attractive decorative ridges and overall pleasing design
+good balance of size, weight and blade length
+solid overall construction
Towards the more neutral traits are the pakkawood scales. Mine came fairly dark brown and subdued so they could easily be mistaken for real wood at first glance, which is a plus. On the other hand, the scale on the non-locking liner (don’t know what else to call it) does not extend as much towards the ridges as the other one. In other words the scale is slightly smaller, which leads to more of the ridge protuding over the edge. I estimate the discrepancy to be just under one mm.
The neutral:
-large variation in handle color (something to keep in mind)
-one scale is slightly smaller than it should be
-pivot is mounted upside down
However, the knife has a major shortcoming that has to be corrected. At first glance the blade is well centered and even though the detente is strong and deployment somewhat stiff - it functions well. After a hundred or so openings and a bit of carry I noticed the clip loosening and the centering moving toward the non locking liner.
It turns out that the clip screws protrude so far from the liners that they push the pushes the brass washer upwards and into the knife. This actually held the blade centered. I loosened the screws and free from the pressure of the screw the blade moved from the off center position.
The bad:
you will need to disassemble the knife and file down the clip screws (take that opportunity to mount the pivot the right way up, to clean the knife and keep in mind that the screws have thread locker on them and if its one of the strong thread lockers you may not be able to open them without stripping one of the screws that holds the scale in mine would not budge)
-you will need to play around with the pivot tightness until you get decent centering
- it will take a while for the action of the knife to smooth out (many openings), so that it is both smooth and remains centered
- the clip screws come undone over time so either loctite them or live with it
- the protruding ridges are uncomfortable if you hold the knife tightly - they dig into your palm. I tried some wood whittling with it and it hurt my hands more than necessary
- the brass washer needs polishing with some fine sandpaper
Bottom line:
This knife is really good value…if you’re willing to fix its shortcomings.
