Hi all,
Update 30/06/2014
the last update is here Ervin's try (2nd. Annual BLF Scratch Made Light Contest) update 6/23/2014 finally beam shots of my new thrower because this page can not take anymore of me ![]()
Update 27/06/2014
I am making a small update at current progres. Have made considerable progress but don’t have time to post, but since i have not much time i am posting this from my phone on the go just in case.
This is as it looks right now.
Will post how i made if i find time later.
well you know what is for, details will come later.
Have one or two ideas in my mind, still undecided what to go after. Can we try 2 projects at once or is against the rules?
edit 25/04/2014
ok I have to start it, because you never know how the “free time” will treat you in the future ![]()
I think i have an simple idea. I have not cleared it all in my mind, but am very clear on what will start building. so first thing I am going to focus is the place when the led will sit.
I consider it the most important thing in my build, the heart if we can say. it will have to keep the led safe and cool and on base of how it come, it will determine the all other parts, like head and body for batteries.
need I to say that will use cheap parts than can be easy obtained? ![]()
now I have to think about something strong and with a lot of metal in it ……
edit 27/04/2014
I think I have find something to start. I have this things that stay around in my desk from some times.
i believe a 16mm cree will find its place there just fine. I just need something to rise the mass and also help radiate the heat, well we all think of cooper in this point… but hm… where i can find cooper ? I am looking around in my work shop and thinking… I think have found something.
well I need to improvise something here. lets make a try
this is going to my nerves ![]()
now is starting to take shape(a strange shape but its a shape :p)
hm looking at it …
what the hell am i doing ??? ![]()
but i think it should work in the end, just i have to find a way to make it little more uniform…
well improvise something fast again
hah i did not think before than in my life i would have ever thought for ways how to manufacture something ![]()
looking good and almost equal to me ![]()
ok no more time for today. lets see if i will have some tomorrow…
edit 2/5/2012
…that tomorrow was very busy day, not a chance to play with project.
whenever i have some free time I like to think about the project, how this and how that. for now i tend to focus on how will build the head, what driver, and what battery setup to use.
the more i think the more i like the idea of creating a useful light for my need(which are play and experiments :p) so i will try to make as more universal in parts as i can. for example I always have wanted to play with one of those 78mm asphericals for throw and what holding me back almost always have been one suitable host that was not expensive enough to destroy in mods. now i think will make one from myself ![]()
so head will be big and easy modifiable, also easy to change with a new one if needed.
driver will be made from scratch(i hope, if fail will use some ordinary one) and will have a big range of A output.
I think I have under valuated building a driver, the more i investigate, more difficult it become ![]()
have some crazy ideas, hope they are not impossible to realize in the end too :bigsmile:
battery , well i will try to use both AA and 18650. (as much universal as i can philosophy ) still undecided to go with 6 AA or 9 and 1x 18650 or 2 or 3? in the end this will be more an aesthetic choice and ergonomic.
led will be changed easy if i make progress with driver(xpe, xpg,xml) not sure on mtg2 need to read more on characteristic of that led.
well thinking about all this things and feeling almost lost
I think now to focus on all those problems individually till i resolve one and then go to the next one just to keep my interest on project alive with smaller victories :bigsmile:
for now my desktop is a big mess :
today i made a small progress with feeding the led(xmlt6). have made some research on how AMC7135 work and finally was able to connect one (one 380 mA type)
was not sure at first and when put the led on it sounded like too much light for one AMC so i make some measurements. fortunately everything was ok as u can see on photos
this little electronic circuit are very hard to play because of small dimensions:
but in the end i succeed to solder one somehow.
I made some temp measurement bc on theory there is some heat that it is needed to disperse from there(IxU=0.35Ax~1.4V=0.49w ) and after 30 sec i measure around 47 grade Celsius from 22 that was the room:
oh too late again, soldering and posting took me like 3 hours, probability my wife will kill me when i go home now ![]()
edit 5/5/2014
lucky me i managed to stay alive
so…
Driver +*
Well I have one idea since its from scratch contest why not try to make a driver too? This got me to thinking about it. A lot of ideas come and go in my mind but to keep it simple in here i will try to explain only those i thought where more doable and simple. (all this is in the name of “ unique “ , if I fail than will use just an simple ordinary driver
Idea 1 :
Why not o use a simple resistor to control the Amps the led gets? It’s simple, no? Even better since we are thinking about resistor why not include an variable resistor or what is know as a potentiometer? Normally an linear potentiometer should do the trick and the good thing about it, is that we gain total control in led output from 0 to the max and differences are unlimited(analog solution ) not like an finite number of choices we usually have in our digital drivers (for example like 3, 5,1, or 100 pre fixed positions)
Ok enough with theory but can it work in practice? Yes sure, the only standard it needs to accomplish is to mach the max total power of the led. For example you will use an XML at ~6 Amp well just be sure to find a potentiometer that is rated above 20W (25 or 30 will be very good). Do they exist? Yes i make a quick search on ebay and they cost around 15$ if I remember right. Problem is they tend to be big and heavy with increasing wattage and i don’t have any one around to experiment soo…
Idea 2:
Why not make it simple and use batteries direct on leds? Hmm max current but not any control on Amps… max performance but to much stress on led and battery and also little bit concerned on safety side of things… efficiency will be max (no driver in between to introduce loses ) but its to easy and not so safe hm… not a good idea for me
Idea 3:
Well I have some AMC 7135, why not try to use them? They behave pretty good with steady output in I are small and relatively cheap. I like them but damn are so small to play with inappropriate tools. I have just an solder some wires and that’s all, how to use them? Ok first I thought of this simple idea to put 10 AMC in parallel and to be able to select all one by one or all at the same time. Some sort of variable driver with 10 preset position in Amps like: 1-350mA,2-700ma, 3-1050….and so on till the last 10-3.5A.
Theoretically is easy but in practice when I try to realize what i have in mind was a sort of nightmare because AMC are so small and I never thought how hard is to solder them
Below is a schematic how I thought to realize:
The third contact is some sort of metal that will make mechanical contact and moving up and down in the third row of pins (maybe not exactly that pin but GND for example)
Well I liked the idea when I was thinking about it but fail miserably in trying to solder and make it usable in practice ( and i don’t lack the skill or patience in soldering
) just i have only some wires an soldering and AMC which are to small to little to realize as I wanted.
Well I do not give up easy so focus on thinking how to realize my idea in practice got me to this type of implementation. I thought why not to use simple switches to power on/ off those AMC ? Normally a panel with 10 simple switches in row that command those little current regulators should do the trick and be doable…
Thinking about it, the interesting bit is that are not needed 10 switches to control 10 AMC. With just 4 of them we can get 10 levels of output in different combinations
Example :
Well it sound doable to me and good thing was I have one motherboard with one DIP switch with 10 positions in my office. Old motherboard was like this before
After ![]()
And DIP swich ended here
a view of how it is right now for testing
Long story short it works. (an very general idea of what i am doing, or not doing :P)
I don’t know how reliable will be this switch in time (because DIP switches usually are not uses for switching power but are used for low current in logical ports and so on . ) but for now it work very well.
I am doing measurements in output like current and Vf of led but it looks Ok.
Later will post detailed result, total scheme how I connected with photos, how it can be better , because again my free time end here.(6 hours I spent only with soldering alone and today like 2 hours with posting and making schemes !!! )
edit 08/05/2014
Ok back again from the lab (three working days!) ![]()
This update will speak for driver. I managed to finish (almost) and also did some measurements in output and some schemes. Now i only have to think for ways of putting driver on flash making attention that wires being as short and as thick as possible where it count. An optimization revision if we could say. As is, it work but lot of loses are introduced because of long and thin wires and lousy and too much connections in between.
I have never worked with drivers before, have a very general idea how they work, but being over-saturated with electronic stuff (because of my work) I never take the time to study them in details. Well making my driver for project changed situation I was forced to start read on AMC. Once i grasped the general idea on how they work I started to play with them. Well first thing was needed to solder one AMC and make LED glow.
But soldering those tiny AMC was difficult.
Just one AMC is relatively easy and in fact I soldered it fast enough:
Problems start when I needed to solder two of them. I never thought would be so difficult. In the end just found some ways that worked for me. Below some photos of how realized this:
The same method I use (despite being more difficult this time) soldering 3 of them together:
When i try to repeat the process with 4 it was again impossible, the holder always failed
to keep them and they always ending in my table. Part of the problem was that I put some solder in the pins before to make soldering more easily in the end and because I do not wanted that they sit very close to each other because of heat radiations.
Well this brought me to the next way of soldering them. I used my copper wires as shown in photos:
Once I started to solder than was easy. Maybe in the final design I solder the other stacks of AMC this way because I believe that soldering GND in pill will really help in heat and
reliability.
Next step was soldering DIP switch. I just start with my single AMC in the switch number one. Once that it work other part was just repetitive and easy. The end result:
All wired together i started make measurement curious how it will work
Results were so so, but I believe that there is very room from improvement in performance in the end product because i will solder all wires and will use short ones and thick. Also contact with battery will be better and also missing connection for I will improve too. Battery was not full but 4.08 and protected. So I have faith.
As it is i use 4 stacks of AMC in 1,2,3,4 configurations getting 10 combinations from 0.38A to 3.8A in theory but thinking on it I optimize it and in the end will use 15 AMC in total (from 10) in again 4 stacks but in 1,2,4,8 configuration getting 15 combinations with outputs from 0.38 to 5,7 A MAX. below is the scheme how i connected, yet to put capacitors but I think will put in the end. Also tested a low output adding a resistor 10 ohm parallel with led and in use with one amc. Not sure on safety thing on this it works but will test more later…
total scheme:
well with this i consider close the driver section on my review.
I know you like to se more metal work and i ask sorry if bothered anyone with this part, but it was fun for me to realize it and who knows maybe some other electronic folk out there will find it interesting and helpful.
Next step is design and back again me, that bash my head to the metal, hoping it will bend as I wish: p
Some ideas what I am aiming for
And the very very very good thing is that in my office now arrive these:
