Trying to make a chart for reference purposes so it will be simple non-tech persons to check with a volt meter, check if this is correct.
Estimating Resting Voltage vs Remaining Capacity
The Li-on is relatively correct. These are approximations and it varies depending on the quality/age/use of the cell.
The NiXX one….well, you simply cannot est. remaining capacity to any useful degree with voltage, especially if unloaded.
You can take a completely dead NiXX, put it on a s l o w charger for 10” essentially putting in nothing and it’ll tell you it’s half full if you check it.
