Even products with a legit UL listing and big brand name can have poor quality too
Take a look at direct from china stuff.
UL is world ahead of chinese junk. Bad ones will always slip in.
Saying UL listed is poor quality is simply a disservice to BLF. Enough people already think “its all the same”, “its all made in china anyway”.
If all else fails, a brand name UL listed product gives you someone to go after when their quality control fails.
Hi guys, please make sure any comments here don’t turn into a USA vs. China bashing controversy. Thanks in advance.
I only have an issue with dangerous products. Certainly no problem with chinese. Hope I didn’t give that impression. I used “chinese junk” only to mean the hazardous products not all chinese products.
I'm not saying that. This only shows that a UL listing and big brand name isn't a guarantee of good quality.
That's true. Hopefully that's not after an expensive loss of belongings and home though. Money doesn't replace everything.
ul listing stickers are regularly forged just like brand names.
Sorry for being harsh.
Imo UL could indeed be better. Just don’t want people to be turned off and not bother to get UL. It seems to be the best we have.
Being able to go after them isn’t so much about money to me, rather just the fact that they are within reach creates incentive for them to act slightly better.
As you say money doesn’t replace everything. Wont ease pain, recover life or easily replace a real ‘home’.
You can check UL numbers online. Need to buy from reputable dealers though. Else you still run the risk of a well done counterfeit with every detail copied.
I hope you're right and that we hear and announcement from that manufacturer soon. They could easily fix the problem. Hopefully they're not like Warsun and refuse to make a simple fix that would make a big difference to their customers, which in this case would be worse since it's about safety.
I note that the label says “Designed in the USA” but carries no indication of where made. Could be China or another low labor cost country. UL, CSA and other safety approvals are based on inspection and certified safety tests of pre production samples typically along with factory inspection to make sure that safety test equipment such as HYPOT test equipment has up to date calibration stickers and is being used to test every production unit to documented procedures. Actual UL workmanship inspection of individual products does not happen based on my accompanying UL and CSA inspectors on their factory visits unless a major safety problem has been reported.
Try to permit parts without a UL number. It’s not going to happen. It stops people from burning their house down. The guys I don’t care for is OSHA because a lot of the products they forced on printers back in the 90’s didn’t even work. I know stops cancer- ect… But if the replacement solutions can’t do the job, your going to have to trust the years of experience to make sure people protect themselves properly.
UL is good though. A lot of Chinese parts are UL listed too. :beer:
Looks like the admin wants me to change my username so if it’s Flashhole instead :slight_smile:
That very same APC power bar/surge protector pictured in the article is protecting my computer as I write this comment. I never realized that it is now considered vintage. Quality issues can hit close to home.
A label and a brand name are not a guarantee of quality. Ask the owners of the 22-million General Motors cars that have been recalled in last couple of years for a myriad of problems. At least 13 people have been killed in accidents caused by the ignition switch problem alone.
“As goes General Motors, so goes the nation” is credited to Charles Wilson, former president of General Motors and later US Secretary of Defense. The saying was true in the 1950s, given as the reason for the GM bailout after the 2008 US financial crisis, and is still true today. GM shows us that it may be even harder to maintain quality than it is to establish quality control in first place.
Quality control and maintenance is an issue everywhere, particularly when lives are at stake. Thanks for the warning.
I guess this means we don’t drive certain GM products with faulty ignition switches. :wink: I don’t think a UL sticker on that switch would mater much as GM has problems taking ownership due to lawsuits…at least a flash light hasn’t killed?
Trust. But verify.
A couple GM CEOs should see actual prison terms imho. When coverups are documented you need actual responsibility. Fines against the company are a joke.
Again, UL seem to be the best we have. You’re not saying if UL doesn’t protect 100% every time out of the millions of products sold then why bother, right?
Reading the comments at Tom’s, that “vintage” APC was ten years old, and the second one the author checked didn’t have the problems; there’s talk of looking at newer models, which is good.
I suspect the message is, look at what you buy when you buy it (or before the warranty runs at least).
I’ve redone the occasional cold or bad solder point on a lot of 110v devices — power strips in particular, after I read that quite a few home fires are caused by shorts inside power strips made of plastic that burns very hot and fast once ignited.
Maybe mistrust, and verify, is more appropriate.
Nobody out there is in business for our health.
IMO the problem with the GM switches is not the kind of thing that UL would have caught any way. It was a circumstantial thing related to heavy key rings with a lot of keys and other items on them per my understanding. Mechanical over stressing of a inadequately designed component caused a mechanical failure that then caused a unexpected switch opening. What weight of key chain should they test with? Hang an Olight SR90 on it? How GM handled the problem once it was identified is the criminal thing IMO.
, I have not seen a UL sticker on any GM or my Tundra accelerator for that mater. I think that Underwriters Laboratories would be a good first step for many electrical unknowns, at lest for many that have not a clue in how to trust and verify?
UL verifys the very expensive Pelican lights my company uses in the offshore arena where I would be written up for using a light such as the M6.
it’s about safety.
My parents both worked there in the 50’s.
It’s where they became acquainted and started dating.
Both were chemists, later attorneys, and told us about their work.
It’s a private company, not government accepting products for voluntary testing.
About UL Media Center
UL is a global independent safety science company with more than a century of expertise innovating safety solutions from the public adoption of electricity to new breakthroughs in sustainability, renewable energy and nanotechnology. Dedicated to promoting safe living and working environments, UL helps safeguard people, products and places in important ways, facilitating trade and providing peace of mind.
The last I knew UL was primarily concerned with electrical safety and items such as flashlights that do not have any AC connection and are low DC voltage throughout are not considered hazardous or to require UL or other electrical safety agency such as CSA or VDE approval. The same for vehicle electronics I expect though hybrid and electric vehicles may well have some approval requirements. Historically what needs to have UL or similar approval has been determined by the insurance industry, not by Government requirements. Your house burns down due to a fire caused by a non UL approved device and the insurance company may not pay you for the loss.
LOL thats the surge protector connected to this computer that I’m using now. Had it for about 5 years. Looks pretty bad, however unless they open several from different manufacturing dates, you won’t know if that kind of sloppy assembly is the norm, or just the exception.
