Battery 3000mAh WURKKOS USB-C charge at 1.3A. You can use the Keeppower USB-C 4000mAh battery, same dimensions than WURKKOS 3000mAh USB-C battery but 1000mAh more capacity.
THROW is threaded and can be opened with rubber gloves. SFT-42R 6K low CRI good tint.
FLOOD HCRI 4K are push fit and is more diffcult to open. See this post:
Yes. White cable is the positive (+)
I have done some test continuity with a multimeter and the protrudes to polarity protection are not connected to negative (-) that is fine and not connected between them. Screws near led must be the negative.
Magnets are very strong and clip very good. Well done, Wurkkos.
The feel of lateral switch is good, not loose, not rigid, and the central switch is fine, no more room to big button but very good.
The light’s balance can be improved by having it stand on its tail end, with the switch facing upward. It stays upright reasonably well, though it wobbles slightly when you set it down. This could be fixed if Wurkkos included four little level contact points around the power switch; however, that might unnecessarily complicate the design, and as it stands, the flashlight can still be balanced effectively when resting on its tail.
Interface is good and well thinked. You can go from moonlight to another level from off. No possible disable memory level but you can off and up from moonlight to down the level without having increase light level.
Leds are fine, good tints, and the flashlight can be modded. Not glue on threads.
Flood can be improved with DC-fix. No problem to me the outer ring from flood only noticeable from very short distance to white wall.
It is very difficult to find any flaws, considering the size and design constraints. They have chosen the perfect format for an EDC tool with triple functionality, low weight, and a compact footprint. If the durability of the electronics and the switch proves to be good, then this is a 10/10.
18650 batteries flat top not work with adapter from Convoy because protrudes are tall than convoy adapter protrude Reason is thread flashlight, not work with convoy adapters. But you can use in emergency situation 2x (7x2mm) magnets. I tested it with Murata Sony 18650 flat top and works well but is not recommended use magnets on positive pole. Only for emergency. Anyway the protrudes to polarity reverse protection are isolated and must not to be a problem.
The black head Wurkkos battery is the default when you buy a flashlight 18650-usb-c with battery inside. The white head is if you buy apart and charges at slow rate (1A vs 1,5A) and dimensions are a little more in length.
