…. and I’m thinking it might turn out to be more trouble than it’s worth.
If I look hard enough I might come up with a replacement 4” lens assembly with two to three LEDs of comparable output and far better pattern spread.
Thing is I’d prefer to add my own LEDs of brand, level, volts, and color temp.
This is what might come of an initial attempt at mounting the two XML2 LEDs (which just arrived from digikey) in my existing four inch lens drawn exactly to scale…
Pardon this from a ‘newbie’ but this seems to be making zero use of the reflector itself. No?
And obviously I’m going to either end up with two separate bright spots ahead of me or if I cant the LEDs inward then I’ve made even less possible use of the existing lens. Seems like a non starter. The lens was designed for a filament burning near the focal point of its parabola.
What would be ideal would be a 4 inch diameter replacement lens alone with two to three separate parabolas within such as I’ve seen in most larger LED flashlights.
Anyone know a link for such? I’ve looked all over ebay and only found flashlights, not replacement reflectors.
