M4D_M4X
(M4D M4X)
May 26, 2014, 8:37pm
1
Hey guys!
I like my sunwayman F40A!
I like the diffusor!
but: i don´t like to put the diffusor on the light…
-> it is so precisely fitting that air is trapped and pops off the diffusor sometimes.
a way to get that thing in place is to wiggle-waggle the diffusor until it stays in place
oooooorrrr:
drill a hole (i used 1,2mm because it was already in the drill) a tiny bit below the step!
works perfect!
The simplest ideas are always the best. Good job! 8)
wight
(wight)
May 27, 2014, 2:11am
4
Nice tweak. What do you normally use your diffusor for?
nice idea… but don’t you want it tight fit so you can hang it upside down? :~
Boaz
(Boaz)
May 27, 2014, 9:00am
6
how to relieve air pressure from a plastic cap ?
seemed like a no-brainer
On the other hand ...... it's a smart place to drill the hole.
M4D_M4X
(M4D M4X)
May 27, 2014, 7:55am
7
i would not do a modification if it made something worse
it stays put as before i drilled the hole!
@wight :
since now: just enlightening the crap in my basement
but i think i will use the duffusor in caves to get a good 360° flood for pictures
Strick9
(Strick9)
July 20, 2014, 7:36am
8
I just drilled a hole in the diffuser the same way you did…
It’s so much better (and it still stays on snug)!
Thanks for the idea!
M4D_M4X
(M4D M4X)
July 20, 2014, 8:03am
9
a simple mind has often good ideas…
Thanks M4D M4X, doing this right now. The only thing I didn't like about one of my favourite lights, is fixed
