Anyone know anything about this bugger?? Sounds pretty solid on paper. I am not familiar with “Fandyfire”. Quite the name that.
2-mode is perfect for me. Emitter could be better, not very efficient… but I still think I’m gonna pick one up. Cheap enough to give a shot, right? If they had an XP-G or XM-L version I would have ordered 3 already.
Don’t snatch all the stock before I get one! DX Link
So I ordered a couple S1s from manafont. At 10 bucks I figure decent beaters if nothing else.
Arrived in OK shape. Had to tighten down the reflector to stop rattling. Also backed the switch down a smidge to fit AW IMR 16340s.
Overall I like the size, feel, and form of it. Nice clean simple lines. Knurling is subtle, not rough. Crenelated bezel is not stupid sharp on mine. Clicky has decent feel, nothing too special.
UI: one click on for high, another click for medium (or ‘not-so-high’), another click to turn off. No soft press or half press. It takes a full click each time. No memory. Simple cycle. You could say its 3 modes - hi/med/off.
Works with lithium CR123s, but obviously meant for 16340s. There is virtually no perceptible output change between mode 1 & 2 on Cr123s. Guesstimating about 160 lumen on cr123.
On 16340 it is a two mode, UI as explained above. You could consider it ‘turbo’ and ‘high’ maybe? If I had to guess I would say output is about 220 lumen on high and 180 on med on IMR.
This funky mode behavior makes me think it prob is a resistor as someone mentioned already. I did not disassemble to check.
All considered, not a horrible purchase for beater duty. I’m sure these will be rolling around my garage floor in the future.
If you have higher expectations or needs to fill might be best to spend 5 bucks more on something with proper modes.
Yeah it might. Size and weight would permit it. Not sure how well it would handle recoil. Probably OK with smallish calibers.
I forgot to review the beam pattern… Nothing crazy. Pretty much what you would expect from an XRE this size. Well definded hot spot with a bunch of spill. Throw is typical for this size.
The bigger headed S2 version mentioned above might be better for gun use. I did not go with the S2 because size/wt are more important than throw for my intended use.
