Are discontinued items are no longer archived? They still show up in search results but get redirected to unrelated item
This is the ugliest light I’ve ever seen!
Hey mate do you know what LEDs are in this? Could you find out?
[/quote]
It lists it as an XHP70 in one of the photos.
Are discontinued items are no longer archived? They still show up in search results but get redirected to unrelated item :weary:
Yes, we have gradually removed the discontinued items from our website, thus customers can find out the items they want faster. Hope you can understand.
fasttech:3*LED 6-Mode 3900LM LED Flashlight
pure white / 1*26650 / IPX5 waterproof / power bank function / multi-stage heat dissipationHead diameter: 55mm
Tube diameter: 50mm
Overcharge and overdischarge protection
1.5m drop protection
The LEDs are XHP70.
LED 5-Mode 4800LM LED Flashlight w/ Focus Zoom
pure white / 2*18650/2*26650 / lanyard / IPX4 waterproof / USB output
SMILING SHARK Q28 Tactical Diving LED Flashlight
1*LED / 3-mode / 1200LM / pure white / 1*18650 / clip / IPX7 waterproof / heat dissipation / three light source adjustment
Thickened waterproof ring, insulated and protected design
is the SMILING SHARK Q28 body made out of plastic or aluminum?
It look plastic but wanting to be sure
flightless22:Are discontinued items are no longer archived? They still show up in search results but get redirected to unrelated item :weary:
Fair enough. I’m apart of the minority of customers who like to peruse old catalogs just for information.
The body material is ABS plastic.
A cute headlamp—-Hand Wave Activated LED Headlamp w/ Hollow Reflective Headband
6-mode / 270LM / pure white / red light warning / yellow fog lamp / USB rechargeable / IPX6 waterproof / angle adjustable
2m impact resistance
Another headlamp I would like to share is 6*LED 9-Mode 250LM LED Headlamp
pure white & red warning light / USB rechargeable / hand wave activated / IPX4 waterproof / power display / 60’ up & down adjustment
1*LED 5-Mode 2300LM LED Flashlight w/ Focus Zoom
pure white / 1*18650/1*26650 / lanyard / IPX4 waterproof / USB output
6-Mode 800LM Dual Light LED Flashlight w/ Focus Zoom
pure white & red & blue light / 1*18650/3*AAA / magnetic tail / water resistant
3PCS SMILING SHARK K07 LED Headlamp
1*LED + 2*COB / 4-mode / 80LM / pure white / USB rechargeable / IPX6 waterproof
Upgraded Solar Powered Rotating Color Projection Lamp for Outdoor Garden
3*LED / 2-mode / RGB / IP55 waterproof / 2400mAh battery
Solar panel: polycrystalline 6V 250mA 1.5W
Rotation method: reflective prism rotation (will not break)
Switch position: 2 mode switch (winter and summer mode)
Illumination range: 3-4m
Light-emitting mode: RGB (red, green and blue light motor rotating lens emits alternating color light)
3*LED / 1-mode / RGB / 500mAh battery
Solar panel: Polycrystalline 5V 80mA 0.4W
Rotation method: lamp bead plate rotation
Switch position: 1 mode switch
Illumination range: 1-2m
Rotating motor: 3V long life, brushless DC motor
Working principle: It is dark, the light is controlled to start, the motor drives the red, green and blue lamp beads to rotate, and the light passes through the reflective lens to project a rotating colored light
Convoy M21B LED Flashlight
1*Luminus SST40 LED / 4-mode / 1500LM / neutral white / water resistant / 1*21700/18650 / anti-skid body
Head diameter: 35.7mm, Tail diameter: 27.1mm
Convoy M26C LED Flashlight
1*Luminus SST40 LED / 4-mode / 2300LM / natural white / IPX8 waterproof / 1*26650 / anti-skid body
Voltage: 3-4.2V
Head diameter: 55mm
Tube diameter: 33.5mm
Tail diameter: 33.5mm
