Variety of Flashlights On Sale - Up to 15% Off from Top Brands
Convoy M21F 2000LM 6500K LED Flashlight
OSLON Boost HX KW CULPM1.TG emitter / smooth/stepped ramping / 1*21700 / IPX6 / 748m throw / 8A output
Head diameter: 40mm
Tube diameter: 27.5mm
Tail diameter: 29.5mm
Required battery type: 1*21700 battery (length not more than 71mm, please do not use pointed battery with protective plate)
Mode operation instructions:
- Click the button —> Flashlight turns on at last brightness —> Press the button, increase the brightness —> Release and press the button again, increase the brightness
- Flashlight off, press the button —> Moonlight mode (0.2%) (This brightness will not be remembered)
- Flashlight on or off, 2-click the button —> Turbo 100%
- Flashlight off, 3-click the button —> Strobe
- Flashlight off, 4-click the button —> Tactical mode, only 100%, 4-click the button again to exit the tactical mode.
- Flashlight off, click the button —> Voltage detection (* means “flash” , * pause means 3.7V, )
- Flashlight off, 6-click the button —> Switch from normal ramping mode to 4 modes 1–10–40–100
- Flashlight off, 10 button clicks —> Lock mode, the flashlight will flash once under any operation, which means the flashlight is located. 10-click the button again to exit lock mode, please note this is the only way to unlock.
The flashlight has low voltage protection and temperature control protection.
TANK007 TK568 130LM 6500K LED Flashlight
authentic / Cree XR-E emitter / 1*AA / IPX8 / 120m throw
- Head diameter: 22mm
- Voltage: 0.8-4.2V
Manker MK34 II 20000LM 6500K Compact Lightweight LED Flashlight Searchlight
authentic / 12*Luminus SST40 emitters / 14-mode / 3*18650 / IPX8 / 350m throw / 30625cd
Main specifications:
Tail diameter: 46mm
Working Voltage: 8.7V - 12.6V
Waterproof: IPX8 (Submersible to 2m)
Impact resistance: 1 meters
Features:
Utilizes 3 set micro-orange peel quad-core reflectors for uniform and softer extensive peripheral illumination
High efficiency constant circuit provides stable output (Non-PWM)
With advanced intelligent temperature regulation module, MK34 II regulates its output and adapts to the ambient environment, maintaining optimal performance
Electronic reverse polarity protection and over-discharge protection
Integrated indicator in side switch indicates remaining battery voltage
User-friendly Interface, easy & fast one handed operation:
- One button control all brightness levels and functions
- Five user selectable moonlight mode(0.1 - 2 lumens) to meet different requirement
- Single click to general mode, friendly adjust 5 different brightness levels
- Double click to enter Turbo from any modes (except lock-out mode)
- Triple click to special mode:Strobe/Beacon/SOS
- Memory function stores brightness level last used
- Lockout mode prevents accidental activation
Constructed from aircraft-grade aluminum alloy
Premium type-III hard-anodized anti-abrasive finish
Triangle shaped flashlight head and ultra-compact flashlight body allow the end users to operate MK34II easy with one hand.
Integrated battery magazine design allows for a lighter and more compact body
Three-sided cooling fins improve heat dissipation performance
MK34 II can be directly mounted to a tripod, turning it into a camp light or a fixed supplementary light
Chrome plated stainless steel bezel ring protects core components from damage
Utilizes stainless steel button with CD pattern surface for good touch feelings
Immersion gold and gold plated connector to ensure an effective conductivity
Built-in lanyard hole (inner diameter: 0.157”/ 4 mm)
Trapezoidal thread offer high strength and durability, allow tail cap twists smoothly
Convenient tail-stand capability
Battery Installation
Insert batteries with the positive (+) and negative(-) ends corresponding to the diagram on the inside of the battery compartment.
Tighten the tail cap by aligning the two metal pins on the tail cap with the corresponding holes on the flashlight body, and rotate clockwise.
Warning:
- DO NOT mix rechargeable and non-rechargeable batteries
- DO NOT mix batteries of different types/brands
- DO NOT mix batteries of different power levels
- DO NOT mix old and new batteries
Thermal Regulation: Advanced intelligent temperature regulation technology allows MK34 II to dynamically adjust output performance according to its body temperature. The cooling fins are also designed to achieve an excellent heat dissipation performance. They prevents damage from overheating and prolongs its working life.
Note: DO NOT submerge the flashlight into any liquid when it is hot. Doing so may cause irreparable damage to the light due to the difference of air pressure inside and outside of tube.
Power Indicator
When MK34 II is turned on, the built-in power indicator under the inside switch will show different lights to indicate remaining battery voltage:
- While battery voltage > 10.2V, blue light turn on and last 3 seconds.
- While battery voltage 9.6V - 10.2V, purple light turn on and last 3 seconds.
- While battery voltage 8.7V - 9.6V, red light constant-on.
- While battery voltage < 8.7V, flashlight turn off authomatically.
Operation Instructions:
ON / OFF
- ON: When the light is off, single click, long press, double or triple click the switch to turn it on.
- OFF: When the light is on, single click the switch to turn it off.
General mode: General mode: While OFF, single click switch to enter general mode. Press and hold on switch to adjust 5 general brightness levels (cycle through ‘Low >Mid1 > Mid2 > High’ or ‘High > Mid2 > Mid1 > Low’). Release switch to select one level you want. Press and hold on switch again to cycle levels through opposite direction. While cycle to last level ‘high’ (or ‘low’), the light will stay this level and stop cycle. After entering in general mode, single click switch to turn it off; double click to Turbo; triple click to special mode.
Moonlight mode: While OFF, long press 1 second to enter moonlight mode. there have 5 lower brightness levels from 0.1 lumens to 2 lumens. Press and hold on switch to cycle 5 different levels. Release switch to select one level you want as the similar operation in general mode. After entering moonlight mode, single click to turn it off; double click to Turbo; triple click to special mode.
Turbo mode: Double click to enter Turbo mode from any modes (except lock-out mode). After entering turbo mode, single click to turn it off; double click or long press to general mode; triple click to special mode.
Special mode: While OFF, triple click switch to enter special mode. Press and hold on switch to cycle through ‘strobe - beacon - SOS’ automatically.
Release switch to select one level you want. After entering special mode, single click switch to turn it off; double click to Turbo; Triple click to general mode.
Button breath flash mode
- While OFF, long press the switch for 3 seconds to enter button breath flash mode (firstly moonlight will turn on and then turn off).
- While lock-out, single click switch to enter breath flash mode; single click again to leave breath flash mode.
Lock / unlock: While OFF, quick quadruple clicks will lock-out the flashlight (4 flickers show successful lock-out). While locked-out, quick quadruple clicks again will unlock.
Memory function: While OFF, single click (or long press) to enter general mode (or moonlight mode) last used.
Warnings:
- Mankerlight flashlights are high-intensity lighting devices capable of causing eye damage or other harms. so please avoid shining our lights directly into anyone’s eyes.
- To protect batteries, driver circuit and LED, we DO NOT recommend you run the light at turbo mode in longer time
- The warranty will be nullified if product is broken down, reconstructed and or modified by unauthorized parties.
- To avoid bad contact, please often clean all metal contact with a clean cloth.
- Every 6 months, threads should be wiped with a clean cloth followed by a thin coating of silicon-based lubricant.
- To maintain waterproof rating, please lubricate the O-ring with silicone safe lubricant and replace worn O-rings as needed.
- If the light will not be used for an extended period, remove the battery, or the light could be damaged by electrolyte leakage or battery explosion.
AceBeam X50 40000LM PD/QC 3.0 Multipurpose Handheld LED Flashlight Searchlight
authentic / 8*Cree XHP70.2 emitters / 8-mode / built-in battery pack / USB-C fast charging & discharging / IP66 / 800m throw / 160000cd
- Head diameter: 75mm
- Tube diameter: 51.5mm
Features:
- Utilizes 8*Cree XHP70.2 LEDs with a max output of 40,000 lumens
- Maximum beam intensity of 160,000 and maximum throw of 800 meters
- Beam angle is up to 120 degrees, wider range of seeing
- A step-down constant current circuit design with an efficiency rate up to 98%
- Fast USB Type C charging with discharging function available
- USB Type C 36W fast charging; 1.8 hours for full charging
- Built-in PD 3.0 and QC 3.0 full protocols
- Power bank function output data: 5V/3A, 9V/3A, 12V/3A, 15V/1.75A, 20V/1.75A (Note: When connecting to the power bank with same PD protocol, it might fail to charge if the protocols are not compatible with the device.)
- Built-in intelligent temperature controller for step down bright levels
- Reliable mechanical safe lock-prevents accidental activation
- Detachable handheld handle meets various lighting demands
- One single stainless steel switch provides access to all functions
- Made of durable A6061-T6 aluminum alloy, provided a rigid structure and a fast cooling efficiency
- Premium type HAIII hard-anodized anti-abrasive finish
- Impact resistant to 1 meter
New Arrival! Manker Striker 2300LM 6500K Tactical LED Flashlight w/18650 Battery
Luminus SFT40 emitter / 3-mode / USB-C charging & reverse charging / IPX8 / 500m throw / 62500cd / w/strike bezel
More Specifications:
- Head diameter: 39mm
- Tube diameter: 20.6mm
- Tail diameter: 27mm
Features
- Designed for law enforcement, hunting, and tactical applications
- Maximum beam intensity of 62,500cd and maximum beam distance of 500 meters
- Powered by 1*3.7V 2600mAh high-drain protected 18650 rechargeable lithium-ion battery with USB Type C charging port (Included)
- 18650 battery built-in charging & reverse charging circuit with a USB Type C port. Plug the included USB Type C charging cable (integrated OTG), it can be charged (max. 5V/1A), and also reverse charged to other digital devices, works as a power bank
- High efficient constant current circuit provides a stable output (Non-PWM)
- Electronic reverse polarity protection and over-discharge protection
- Immersion gold and gold plated connector to ensure an effective conductivity
- User interface is simple and friendly. Only 2 modes + strobe, defaults on high mode
- Constructed from aircraft-grade aluminum alloy
- Premium type-III hard-anodized anti-abrasive finish
- Integrated precision digital optics technology provides extreme reflector performance
- Stainless steel strike bezel is removable. Keep it on for self-defense, night combat, and as a glass breaker. Remove and reverse install it for a less aggressive and subtle look, but enough to protect flashlight core components from damage
- Premium cooling fins achieve excellent heat dissipation performance
- Stainless steel pocket clip works on the pocket, belts, the backpack, and is molle system compatible
- Anti-rolling metal tactical ring built for tough situations
- Forward click tactical tail switch allows for momentary-on and constant-on illumination
- Specialized silicone button cap facilitates precise tactical operation with gloves
- IPX8 waterproof standard (2 meters underwater)
- Impact resistance: 2 meters
Battery Charging & Power Bank
- Battery charging indicator: Plug USB Type C socket of the included charging cable into the USB Type C port of 18650 battery, and connect another USB socket to the adapter.18650 battery has a built-in intelligent identified charging function. When the battery is charging, the indicator will be red and keep flashing. After battery charging is completed, the indicator will stop flash and red constant on.
- Power Bank Indicator: Plug USB Type C socket of the included charging cable into the USB Type C port of 18650 battery, and connect another USB socket to the USB port of the digital device. 18650 battery built-in intelligent identified discharging function. When the battery is reverse charging, works as a power bank, the indicator will be blue constant on. When the battery does have not enough power to charge other digital devices, the blue indicator will turn off.
Operating Instruction
- When the flashlight is turned on, it will default on high mode. Soft press without fully clicking the button for momentary on. Fully press and click for constant on.
- Quickly double half-press the button to activate hidden strobe mode, fully press, and click for constant-on strobe.
Warning
- Do not shine light directly at anyone’s eyes.
- Please fully charge the battery before initial use.
- Please check and replace the O-ring regularly to maintain the waterproof rating.
- Please check and lubricate the threads regularly with professional lubricant.
- Remove the battery from the flashlight during long-term storage.
- Please recharge the battery every 3 months when left unused for a prolonged time.
West Biking Smart Light Sensor Bike Bicycle LED Front Light w/14.8Wh Battery
2*LEDs / 5-mode / 800LM / 6500K / Micro-USB charging / IPX6 / power bank function / for handlebar diameter within 3cm
Convoy S21A 500LM 4500K 4-Mode EDC LED Flashlight
Nichia 219B emitter / 1*21700 / IPX8 / 50m throw / 3A output
Details:
Head diameter: 26.5mm
Controller: 4 modes 0.1–3–30–100, maximum current output 3000mA, temperature protection management inside
Driver instructions:
Now we offer another controller version, which has 4 simple modes to switch, which is very suitable for normal users.
Modes: 0.1–3–30–100
The maximum current output is 3000mA.
Its biggest advantage is that you can not see frequency in any mode and there is temperature control.
You can control the flashlight. The temperature should not exceed 55 degrees Celsius, If the temperature of the flashlight is lower than 55 degrees Celsius, it will output full current. If it is higher than 55 degrees Celsius, it will constantly adjust the current so that the flashlight does not overheat.
Tuneng S12 400LM Magnetic EDC LED Keychain Flashlight w/1.75Wh Battery
5*Samsung LH351B / 11-mode / 6500K & UV & blue & red / USB-C charging
IP65 / 200-500m throw / PC & stainless steel construction
Details:
Product use environment: –10’C to 40’C
Overcharge protection voltage: 4.25V
Over-discharge protection voltage: 2.8V
Input current: 500mA
Anti-drop height: 1.5m
FLASHLIGHT MODES Strong > Hi > Mid Hi > Lo > ECO > White Light > White Light Flash > UV Light > Red Light > Red Light Flash > Red & Blue Light Alternating Flash
Wow, what a mess!
300LM 6500K Handheld LED Flashlight w/4.44Wh Battery (2-Pack)
1*P500 LED & 1*COB / 4-mode / Micro-USB charging / over 500m throw / ABS construction
Beam Range: Over 500 m
Flashlight modes: Hi > Lo > Strobe > Side Light
Lens Type: Highly Transparent Glass Lens
Mode memory: No
Reflector Type: Aluminum Smooth/SMO
Switch placement: Handle
Switch Type: Clicky
Tail Stand: Yes
Why Strobo in the regular Modi ?
This is what I call bulls,
Regards Xandre
VOMIT !
I don’t have this rovyvon clone, but I do have an S11. I doubt the modes are quite as described on line, but couldn’t find for sure otherwise.
This is more what the S11 uses, so I think likely.
LONG press/hold > turbo (release to off)
Double click > low > single click > rotate through main modes.
Long press > off
Triple press > side lights > single click > rotate through main modes.
Long press > off
So, you never have to get into the side modes if you don’t want them, and the turbo mode for quick lighting is very easy to access. I find that acceptable.
As a true key-chain light for me, it’s….possible……I might use the flashing modes in some circumstance.
Sofirn LT1S 500LM 2700K & 6500K & Red LED Camping Lantern
authentic / 36*CSP1919 & 4 red LEDs / smooth/stepped ramping / 1*21700 / USB-C charging & reverse charging
Details:
Waterproof: 2m underwater
USB-C charging & reverse charging (5V 3A)
Circuit type: step-down constant current circuit
Operating voltage: 2.8V – 4.2V
Luminous angle: 360 degrees
TANK007 KC11 6400LM 6500K LED Flashlight
authentic / 3*Luminus SST40 emitters / 6-mode / 3*18650 / USB-C charging / IPX8 / 700m throw / automatic temperature control
Details:
Waterproof: IPX8 (submersible to 2m)
Impact resistance: 1m
Head diameter: 60mm
Tail diameter: 45mm
Automatic temperature control: the internal circuit is designed to actively control the temperature. When the flashlight temperature exceeds 55’c, the output will be automatically and gradually reduced. With the heat dissipation design of good heat conducting material at the head, it can be quickly adjusted to the appropriate temperature.
Sofirn HS20 2700LM 5300-5700K & 5000K LED Headlamp Spotlight Floodlight
Authentic / 1*Cree XHP50B & 1*Samsung LH351D 90CRI emitters / 5-mode / 1*18650 / USB-C charging / IP68
Details:
Waterproof: IP68 (submersible to 2m)
Luminous angle: Spotlight: 100 degrees; Floodlight: 120 degrees
Voltage range: 2.8-4.5V
Light intensity: 4647cd(spotlight)/1418cd(floodlight)
Temperature control protection: in the startup state, working for a long time in extremely bright gear will produce a lot of heat. When the flashlight detects that the temperature exceeds 55’C, it will automatically and slowly reduce the output and balance the brightness and temperature to protect the product and avoid scalding by users.
Low voltage protection: when the power is low, the low voltage downshift function will be turned on (the low light and ECO modes will not be downshifted). That is, if it is in the high light gear and the battery voltage is detected below, it will be automatically reduced to the next gear for operation. When the battery is about to run out, it will automatically turn off the output and enter sleep. Please charge the battery in time to avoid damaging the battery due to power loss for a long time.
Convoy S21A 1000LM 4000K 4-Mode EDC LED Flashlight
Luminus SST20 emitter / 1*21700 / IPX8 / 50-100m throw / 3A output
Details:
Controller: 4 modes 0.1%-3%-30%-100%, maximum current output 3000mA, temperature protection management inside
* Now we offer another controller version, which has 4 simple modes to switch, which is very suitable for normal users.
* Modes: 0.1%-3%-30%-100%
* The maximum current output is 3000mA.
* Its biggest advantage is that you can not see frequency in any mode and there is temperature control.
* You can control the flashlight. The temperature should not exceed 55 degrees Celsius, If the temperature of the flashlight is lower than 55 degrees Celsius, it will output full current. If it is higher than 55 degrees Celsius, it will constantly adjust the current so that the flashlight does not overheat.
MiJia 2m/6.56ft RGB LED Ambient Light Strip Kit from Xiaomi Eco-system (EU)
authentic / 120*LED / audio activated / smart linkage / MiJia App control / XiaoAI voice control
Details:
The light follows the color of the TV picture and interacts in real-time (more advanced functions need to be used in conjunction with the Xiaomi TV Phantom following App)
The light supports some Xiaomi TVs
Xiaomi Mi TV 5 Series 55”/65”/75”
Xiaomi Mi TV 5 Pro Series 55”/65”/75”
Xiaomi Mi Full Screen Pro Series 55”/65”/75”
The interaction between the light strip and PC game events needs to be used in conjunction with Razer ChromaRGB or Asus Aura Sync software. The interaction effects of different devices and game lights are slightly different. Please refer to the final actual interaction effect
MiJia App control (Color customization, 3 levels of sensitivity, 4 kinds of dynamic effects)
The light strip can be linked with Xiaomi’s MiJia smart home system. it is compatible with Razer Chroma RGB as well as Asus Aura Sync.
The controller features a built-in microphone to sync with the audio.
The RGB light offers over 100 color combinations to choose from 16 million colors. Users can customize as per their needs from the official App. (Advanced customization function, need to upgrade firmware to 2.1.8_0039 and later)
Connect MiJia App with 8 built-in profiles, which can be linked with Xiaomi intelligent devices
Ambient Light Strip supports OTA software updates.
Rated voltage: AC 220-240V
Rated frequency: 50 / 60Hz
Rated power: 17W (120*0.12W/LED modules)
Rated current: 0.2A
Operating temperature: –10 to 25’C
