Fenix PD25R 800LM 6000K EDC LED Flashlight w/16340 Battery
authentic / Luminus SST20 emitter / 6-mode / 1*CR123A / USB-C charging / IP68 / 250m throw / 15530cd / two-way clip
Details:
The Fenix PD25R flashlight a portable flashlight with a hidden USB Type C charging port. The PD25R blasts an amazing 800 lumens and a total distance of 250 meters. The PD25R is powered by a single 16340 rechargeable Li-ion battery (included) or can operate on a disposable CR123A Lithium battery. The boot-up battery level indicator lets you always know the battery’s status. On/off and momentary-on are activated with the tactical tail switch and six lighting modes are selected with the side switch including a strobe mode. Carry the Fenix PD25R how you want - on a backpack, belt, or Molle system with the two-way body clip. Compact and built-tough with an IP68 dustproof and waterproof rating, this flashlight is perfect for just about any outdoor or work activity.
800 lumens maximum output, 250 meters maximum beam distance.Luminus SST20 LED with a lifespan of 50,000 hours.
Powered by a 16340 rechargeable Li-ion battery and compatible with a CR123A Lithium battery.
Toughened ultra-clear glass lens with an anti-reflective coating.
USB Type C charging.
Battery level indication and low voltage warning.
Instant power activation with momentary tactical tail switch; simple output selection with side switch.
Anti-roll and anti-slip body design; included two-position body clip.
Reverse polarity protection, to protect from improper battery insertion.
Made of durable A6061-T6 aluminum.
Premium type HAIII hard-anodized anti-abrasive finish.
PD25R is deemed fit enough to withstand dust, dirt and sand, and is resistant to submersion up to a maximum depth of 2m underwater for up to 4 hours.
1m impact resistance
Head diameter: 24mm
Tube diameter: 24mm
