I received the Yupard today and it has a purple colored beam, also didn’t realize the lens was plastic. It looked like it had a clear protective plastic cover on it, so I tried to remove the plastic….ehhhh…scratched the cheap plastic lens. Stole a glass one off another cheap light and now it looks better, but no where near as nice of tint as the 14500 model form the same seller.
But, like you said, for less than $6 I am happy.
It was my first aliexpress purchase, but will not be my last.
Thanks!
Keith
DayLighter, that Yupard mini almost made me puke seeing that beamshot. Yuky purple, lol! But.... do you think its would be hard to mod with an XM-L2 and Qlite driver (can it fit?), at maybe 1A-1.5A? Also, how is the build quality, compared to the Solarstorm? It looks just as good as the Solarstorm to my eyes. Thanks for the pics
Finally got mine yesterday. I guess 18 days to Texas isn’t terrible, I’ve seen far worse.
I checked mine and it draws 37.4uA when off. That means my AW IMR 16340 would be drained in about 1.7 years. :bigsmile:
No need to lock out the tailcap on this light. I think I need another one.
No doubt FT is the best deal around on all 3 new models. But if you want a 3C tint though, RIC has it, though you got to pay bout $9 more , plus shipping.
No, NW (XM-L2 T6 3C) is also available from Banggood. At the moment they have a promotioncoupon and the prices are better as the FT prices:
You can choose CW (XM-L2 U2 1A) and NW (XM-L2 T6 C3). I bought one of the SC02 with NW.
I will not buy another flashlight no matter how pretty it is, I will not.
On the other hand, it’s true that I need more AAs, and this SC01 looks great, but I won’t buy it. I will not.
For poops and giggles I took my Ganzo multi-tool (also from FT) and unscrewed the front bezel ring, dropped the reflector and lens and o-ring, held it next to the TIR in the housing, wouldn’t you know it almost EXACTLY the same size…gently folded back little tabs holding the plastic TIR insert, dropped the TIR out, lined up the square in the bottom of the holder on the emitter square on the star (which I am going to be reflowing to a 16mm copper sinkpad shortly), then using a small screwdriver tool that is hollow in the end pushed it down where the reflector was sitting and centering it on the XM-L2 on the star, then dropped in the plastic insert TIR and clicked it in the holder, put in the o-ring and then the lens (it was about 1/32” too short, so the lens made it exactly the same size. Tightened down the bezel ring…and voila…instant dropin TIR.
Almost no hotspot, nice wide flood and still very bright even though you loose some light in a TIR.
Just wanted to give you guys a heads up on what seems to be an almost perfect drop in TIR for the SC01.
Just walked around in the back yard, tons of flood and still good out to about 40-50 yards with a 14500, a AA is a little bit dimmer but just like the SK68 the boost mode is always less bright as the linear regulator mode.
