Faulty sofirn sc32
Can’t seem to get the flashlight to work. Battery is charged via external charger and confirmed charged via the torch’s integrated charge indicator.
The only thing that seems to work is the moonlight when I hold the power button where the indicator also shows a red light.
I thought the torch was locked to did the 4 presses to unlock but doesn’t change anything.
Have a nice time here, Bainimarama!
Might be a bad connection. Make sure the head and tail are tightly screwed in.
Also, just in case the problem is your cell, you should try a different 18650.
Some chatter about this that may help you from an older reddit thread.
https://www.reddit.com/r/flashlight/s/cDFcVaMbMw
Will need to try after the order arrives. Thanks
Looks to be for a slightly different model, I’ve got just the sc32. Tried to follow the steps anyway but couldn’t replicate as the light goes off after I slowly unscrew the head cap.
I bought a sc18 and interchanged the batteries which confirmed the sc32 is indeed faulty. Still haven’t found a fix though
The problem could be a weak ground connection at the tailcap. This could happen if the tailcap wasn’t screwed in tightly enough at the factory.
Unfortunately, the tailcap on the SC32 is glued on. It’s possible to break the glue and remove the tailcap. I did so on mine to increase the switch resistance. However, you’ll probably need some strap wrenches or other tools to get it open without damaging the anodizing.
Yeah, that sounds like it might be a contact issue. It’s glued together so I would be reluctant to put my hands on it, but good thinking about checking the tailcap. Perhaps call Sofirn first to see if they can get a replacement. Hopefully, you will be able to do this without disassembling the light!
