Fenix E01 - Hi-CRI Emitter Swap
Years ago when I got into lights, I noticed a bit of a following around this little light. So I figured hey what the heck, I’ll give one a try!
Only carried it for a couple years before my preference moved to 1xCR123A / 1x18650 format lights, but I’ve always had a soft spot for simple lights.
With the discontinuing of the Fenix E01, and birth of the Sofirn C01, this light captured my interest once again.
Based on the success of others modding the E01 with Yuji Hi-CRI 5mm LEDs, and my quest to purge cool-white emitters from my collection, I thought I’d give this mod a go.
I saw a user on CPF had success with heating the head of the light, and pushing the entire assembly out by the emitter via a piece of tube and vise:
Based on that, I’ll detail my twist on this old mod here - nothing ground breaking, but perhaps another data point for anyone looking to try this - every bit helps.
I owe it to mat_the_cat’s guide for my success with this mod.
By the time I’ve gotten around to writing this, Yuji 5mm LEDs have also been discontinued - but this mod may still be of use to those willing to use a different emitter, or those that still have some Yuji 5mm LEDs on hand.
Potting compound serves to hold the entire driver and LED assembly in place, and must be weakened in order to free the assembly.
At first I planned on making a jig of sorts to sit in a bench vise to apply pressure down through the emitter while I heat the head to loosen the potting.
I found some 3/16” x 0.014” aluminum tubing that I could seat against the dome of the emitter. This tubing was located in the craft metal section of my local hardware store.
I also discovered that a deep-set 1/2” 6-point socket will perfectly cradle the head of the E01, and capture the driver assembly as it falls away while heat and pressure is applied.
Instead of using a vise, I ended up slipping this piece of 3/16” tube over the mandrel of a faucet handle remover (pictured above) - which I use to apply pressure to the LED, pushing the driver assembly out of the head which is itself cradled in a separate jig consisting of the 1/2” socket attached to a metal slug that can be gripped by the faucet handle remover’s jaws.
There’s no reason you couldn’t use the 3/16” tubing and 1/2” socket trick by itself with a bench vise, it just seemed like the handle puller would give a bit finer control of the amount of pressure than my clumsy old bench vise.
Either way, if you have as much junk as I do I’m sure you can come up with something to do the job!
The purpose of the heat source for this mod is to simply loosen the grip of the epoxy from the smooth walls of the driver cavity - it really doesn’t take much heat.
I applied very slight pressure to the emitter with the faucet handle remover jig, and began to apply hot air using a cheap arts and crafts hot air wand.
It doesn’t take much force here, just enough to slide the potted assembly free without damaging components - be gradual with any increases in pressure against the LED.
Once the assembly begins to show signs of movement, I fully tighten the jig to glide the driver out of the driver cavity smooth as silk.
Note that this technique should NOT be used on the Sunwayman R01A, which has a threaded plastic retaining ring holding the emitter in place instead of potting!
This completes the removal of the LED driver assembly.
With the driver assembly removed, some amount of the potting compound must be removed to reach the emitter.
I’ve read that the compound becomes flaky when a gentle amount of heat is applied, and can be then picked away with a dental pick.
That’s exactly what I’ve done, and it works!
Chip off a little bit, stick it back in front of hot air for a sec, chip a little more off. Repeat until satisfied.
Take your time - if you’re doing it correctly, it won’t be difficult enough that it causes frustration.
Be sure not to damage any components with the pick while removing epoxy - watch the inductor especially which has thin magnet wire that is snagged easily.
I try to leave some of the compound around the large inductor, and the brown colored MLCC capacitor near it anyways.
SMD MLCC caps are sensitive to physical shock, and I’ve also seen inductor spindles shatter in other lights when dropped.
The potted driver has certainly contributed to this light’s durable reputation.
With the emitter no longer anchored by potting compound, it’s time to turn attention to the under side of the board to de-solder the LED.
Take note of the orientation / polarity of the LED, and the shape of the leads - the new LED will need to be bent to match.
Note that if the tip of a tinned soldering iron rubs against the battery contact on the driver, that it will leave a trail of solder that tins the battery contact.
This may be a cosmetic issue more than anything, but if you care about that sort of thing you might put a strip of kapton tape to mask the battery contacts off while you do the messy de-soldering work.
I applied heat to the leads of the LED, and gently rock the LED out one lead at a time - careful not to rip solder pads of the board or overheat nearby components.
It’s often helpful to apply a little solder to the end of the iron tip to help heat wick into the solder joint.
If you’re not concerned with saving the old LED, you can also just clip the LED from the leads and remove each lead from the PCB independently from each other (with a set of small pliers so you don’t burn yourself).
This may be gentler on the PCB pads, and make for easier de-soldering.
A solder sucker bulb can be used to clear the vias obstructed by older solder from the now removed LED - again, CAREFUL not to overheat the very small board.
Time to put everything back together!
The silkscreen on the driver indicates the polarity of LED to be installed - be mindful of this orientation when you go to pre-bend the LED leads.
I clamped the new LED in a pair of tweezers, a formed the bends of the leads around the tweezers tips to match the old LED’s bends.
It’s tempting to solder the emitter onto the board first and shove the whole assembly in, but I think seating the LED into the head first will ensure it seats all the way into the reflector.
This would also prevent the LED leads from getting smooshed around inside while you try to force the assembly into the cavity.
I seated the LED into the reflector, inserted the LED leads into the driver pads, then seated the driver into the head before finally soldering the leads.
Once soldered, I use my smallest pair of flush-cut pliers to snip the leads as short as possible so they don’t short or interfere with the battery.
You can assume that this light will be less water resistant after this mod, at least until re-potted.
I’m curious if anyone has re-potted this light after modding, and can share their experiences.
And… that’s it.
Thanks for reading!
you modders are amazing! Envious here.
thanks for your documentation.
Thanks!
I’m pretty new at this myself, mostly fumbling around the garage late at night with a hand full of flashlights until I manage to get one open lol.
So far just doing emitter swaps on glued lights, so I always appreciate those who share their tricks getting them open.
Hope it can help someone, it’s really quite doable despite how tricky it looks when all typed out.
Nice work! Thanks for sharing in detail. I’m still undecided if I ever want to try modding my E01, or just keep it stock to remind me how the Nichia GS days were. I’ve got several Sofirn CO1’s to keep me happy anyways.
Regarding the Sunwayman R01A, I’ve documented a mod here.
One of the pictures shows the threaded retainer. Really the only trick for the Sunwayman is desoldering the PCB from the LED legs.
Unfortunately, it doesn’t seem to be anywhere near as robust as the Fenix. Mine died from a moderate drop. The Fenix, and the Sofirn that is basically a high CRI, floody tribute to the Fenix, rule the 5mm AAA category.
I’ve decided to keep my original E01 stock - it’s such a unique tint that I just had to keep it around.
Bought a couple E01’s specifically to do this mod awhile back, so the first one can remain in its original GS glory.
Your guide for the R01A is outstanding! Came across it last year looking up Yuji mods I think.
Reading again with fresh eyes, there’s a lot of similarity with these lights.
Wonder why they chose such a different construction for the emitter.
I know I’ve dropped a modded E01 about 5-ft onto the garage floor, and it still works great.
Missed out on the Sofirn C01, but I’m glad that they were able to carry on the tradition (with nice CRI!).
Here’s hoping Yuji makes another batch of 5mm LEDs.
LEDSupply has some 15-degree warm white 5mm LEDs, a warm throwy 5mm light might be cool albeit without the CRI of the Yuji.
Might use them if I ever mod an Inova X5 so I don’t deplete my Yuji stash, reading older CPF threads it seems they’re moddable.
Told myself I’d take a break from buying lights to mod, so that’ll have to wait on the back burner.
Thanks to this write up I was able to mod an old E01 I had laying around. I never liked the blue tint, so I threw it in a basket probably 10 years ago. At some point in time I picked up some Yuji 5mm LEDs. I’m not sure what color temp they are but there’s no hint of blue.
Anyway I used a 1/2 6pt deep socket as shown, then used a small size security torx bit to push the led. A little heat and it came right out, using a small vice to push. A little heat at a time and I picked the potting to expose the legs on the LED.
This was my first time trying to desolder an LED on legs, it took me a while. I finally had success by heating up the legs instead of trying to go at it from the opposite side with the solder blob.
I didn’t take pics of the process but below are some shots. I’m not going to try and re-pot it right now.
I know this is a real old thread… but I am curious. Did they have different versions of the E01?
Sorry, I see that there have been three versions. Mine being the latest V2 with the XP-G2 and…yes an optic. A whole different animal… But that head does look a lot like the C01…
Mine doesn’t look anything like the ones above. It seems to have an optic.
I was looking at it and wondered how I would get the optic out?
Actually the light a in the OP looks like the head on my C01S ?
the older cockroach lights seemed to have the 5mm inbuilt pill setup, where the head threaded into rather than onto the body. many newer designs seem to use optics now i cluding the eskte e3a, the olight i3e, and the fenix e01v2. I believe V54, a.k.a. skylumen recently sold a modded e01vn, which had a foursevens selectable driver frankened into it. I assume the optic might drop under from the head, resting on a lip under the bezel…I haven’t picked one up to play with yet.
Yes that is what it looks like. But pressing it…and the emitter/driver out the bottom from the front would mean pressing on the optic… that doesn’t sound like it would be without significant risk.
I can’t tell for sure, but maybe the driver screw out. There are a couple of holes in it that look like they might be for that purpose.
I’ll be picking a couple up soon…I’ll let you know how the disassembly goes. (no promises though, I’ve more a penchant for…**IRREVERSIBLY destructive disassembly.
***maybe I’ll pick up a couple couples…
You guys are right in that pill (w/ both the driver & MCPCB/LED) from this type of AAA flashlight is typically designed to unscrew from the head.
Once removed, the optic (reflector or TIR) is likely to just fall out, sometimes along w/ a lens. If it needs a nudge, a pencil’s eraser should suffice, at least from my experience. Good luck!
