MSRP: $450 - Light
MSRP: $135 - Spare Battery Included, Fenix ARB-L40-12000 (or ARB-L82-12000)
Sale is as is!
Spare Battery Included!
The Fenix LR80R is a high-output rechargeable searchlight with a maximum output of 18,000 lumens and a beam distance of up to 1,130 meters (3,707 feet). It uses six Luminus SST70 LEDs and runs on a built-in 7.2V / 12,000mAh Li-ion battery pack with 45W USB Type-C fast charging.
Key Specifications
• Output & Throw: 18,000 lumens max output; 318,000 candela; 1,130 m (3,707 ft) max beam distance
• Emitters: 6x Luminus SST70 cool white LEDs (around 6000K–6100K, 50,000-hour lifespan)
• Runtime: Up to 300 hours on the lowest eco setting
• Battery & Charging: Built-in 7.2V / 12,000mAh Li-ion battery pack; ~4-hour full charge via 45W USB Type-C; includes power bank discharge output
• Size & Weight: 10.20" × 4.25" × 2.13" (259 × 108 × 54 mm); 57.71 oz (1,636 g) including battery
• Durability: A6061-T6 aluminum with HAIII hard-anodized finish; IP68 waterproof (submersible to 2 m / 6.5 ft); 1-meter impact resistance
Modes & Operation
• Dual Switches: Two side switches control separate mode groups independently:
• Auxiliary / Low (“L”) switch: Controls lower brightness levels—Eco (50 lm), Low (150 lm), Mid (450 lm), and High (1,000 lm)—plus Strobe (6,000 lm) and SOS (150 lm).
• Main / High (“H”) switch: Controls higher brightness levels—Low (3,000 lm), Mid (6,000 lm), High (12,000 lm), and Turbo (18,000 lm).
• Safety & Handling: Features a close-range brightness downshifting proximity sensor, intelligent overheat protection, electronic/physical lockout options, a detachable carry handle, a shoulder strap, and a tripod socket.
