About Fenix TK75
1.Fenix will strive to simultaneously launch separately a running time extension module, but currently has no plan to launch combo package. This running time extension package delivery time would be affected by the peak season orders and therefore may be slightly delayed.
2.Each running time extension module consists of an extension tube and a standard battery holder to provide serial link-betweens with theoretically unlimited extension. However, if adopting more than 2 number of modules, the aluminum extension tubes’ accumulated machining tolerances might render a shorter total length with threads tightened to extreme. The end piece battery holder thus slightly protruded might affect tailcap waterproof. We usually recommend extended to not more than three. The company’s engineers have tried 8 extension modules (i.e. total 9 holders) without problem.
Standard running time extension modules now published with four Fenix ARB-L2 18650 rechargeable lithium-ion proceeds tested in a lab environment. Add an extra module instead of 200%…………….?? to be omitted.
Running time extension package without battery weight is 153 grams, if loaded four Fenix ARB-L2 rechargeable lithium-ion battery, the weight to 347 grams. In accordance with the ANSI standard, our laboratory TK75 mounted on 3 battery holders, filled with 12 batteries (in this case, the total weight of 1400 g) and at the height of one meter freefall to the concrete blocks, in six drop directions with after-drop waterproof test are passed with no
problems.
3. TK75 reflection cup of is of material same as TK22, the highest level of PC material. We dare to use this material comes from what has been adopted for more than a year, the same 3 XM-L light source TK70. We has not received any high-temperature-lead reflector cup deformation or coating off complaints. Within the company test, TK70 turbo mode profile after a five months 24-hour light running test, no occurrence of deformation of the
reflective cup, or coating off the case, while the light output deterioration is 0%! In view of the size less than TK70, TK75 with greater heat pressure at the same time, we try to increase the cooling area and according to the non-downshift temperature rise test results. adding 20 minutes Turbo mode 20 minutes automatically downshift design to ensure satisfactory user experience . Here to remind TK75 turbo mode discharge current is very large, in the course of our testing, the temperature of the battery is always higher than the case temperature, so in actual use, you should try to use the the quality low internal resistance battery.
4. Battery holder design fully considers the compatibility of a variety of cells, the length does not exceed 70mm 18650 battery can properly into the battery holder. Each battery compartment with the the tail negative spring and positive cap built-indesign, and strengthen the seismic performance at the same time, ensure that the the flathead battery can be used normally. Because of 2S2P relationship design, so only with two batteries in series the flashlight can be lit up in case of an emergency, but the running time will be shortened. Due to the current is very large under turbo mode, we strongly recommend that unless in special needs, do not use only two battery under turbo mode. At the same time, for safety reasons, we install in the battery holder circuit cut off design, so that the battery can only discharge, without cross-charging or external charging. So we, in follow-up plan, will not launch the standalone standby charger to running time extension modules.
