Jax Z1 zoomable with extension tube, 22mm FET driver, and MT-G2 5000k LED. First led got damaged, LED in it now is fine. mounted on Noctigon mcpcb, soldered directly to pill. link to build thread here Jax Z1 pics
$120 shipped OBO for it.
Ultrafire 502B with RGBW XM-L led. Neutral White version. color and dynamic white driver. currently on group a. i like this light much better with the convex lens instead of the reflector. currently running OP reflector with a layer of DC-Fix film on the lens. like it better than the convex lens for throw, and better than reflector for up close. good in between set up. asking 30 obo plus shipping or 35 obo plus shipping with a Solarforce L2-CL1 convex lens installed.
Group A (Color):
White High Output
Red High Output
Green High Output
Blue High Output
White-Red-Green-Blue Strobe 8Hz
Red-Blue Police Strobe
Red Blink 1Hz
Group B (Dynamic White):
Die1 & Die3 High Output
Die2 & Die4 High Output
All Dies Strobe 8Hz
Die1 High Output
Die2 High Output
Group A is default, soldering the two stars together will switch to group B.
sorry for the quality of the pics.
will update as pictures of other lights are taken.
I am interested in the 2a tint PFlexPRO - I assume it has the high current mods for the L2P host. About the battery - - Do you use a special charger for the 4.35v higher voltage battery? If so, which one, and do you recommend it? Thanks!
yes, braided tail cap spring, fully potted driver, etc. was all built that way and shipped to me. and i use a xtar vp1 charger, and i would recommend it for sure.
have a Solarforce L2P with Ahorton lens and spacer, running 2.28 amps, ML-L-M-H modes, copper wrapped drop in, de domed XP-G2 S2 1D tint, 668 lumes on high, 196 lumens on medium, 18 on low and 4 on moonlight. not a bad thrower! $60 as is, or if you want to wait till the new bezel comes that will allow it to stand on lens side, and the pocket clip it will be 75. or i can ship the light and bezel/clip seperatly. bezel and clip are on way though.
pictures of light and beam. i dont have a great camera but the lens is perfectly focused. has a good image of the die in person.
