I've been using Way Oil (Mobile Brand) that I think I bought at Enco. I've seen some people just use regular 10-30w. I think I'll be switching to 10-40 when I run out of the way oil. Make sure you use the manufacturers spec oil for the gear box if it has one.
Well on second check, it seems the adapter plate is just fine. Took it off and remounted it, and the face of it is coming out at about .001". I tossed the chuck back on and the runout was only a few thou. Chucked a piece in (snugged it up, rotated the piece and then tightened up the chuck) and it's coming out at about .010" runout 2 inches out, and the datasheet it came with said it measured at .0015". Ugh. The jaws are in the right position as marked on the chuck, but maybe I'll try rotating them around to see if it gets any better. But it's not even that the piece is off-center, it's that it's coming out at an angle.
Now, this is all with a piece that is too large in diameter to fit through the chuck, so it's only utilizing 2/3 of the surface of the jaws maybe. I just chucked in a smaller rod that came out with better readings, but still not ideal.
I think pics would help here Do you have access to a piece of known straight and cylindrical stock? Like drill rod or even a rod out of an inkjet? There are plenty of guides out there for how to test chuck runout, all better than any explanation I could give…
I'll take a video when I get a chance. I chucked in a scrap piece and just practiced facing and turning. Going to see if I can make a simple pill for a L2T where there is a recess in the face to press in a Noctigon and bore out the backside to 17mm to allow for a NANJG 105C w/ adapter ring to be pressed in. The reflector would have the threaded portion cut off and turned down a bit to add a copper collar for heatsinking, and the head would hold it all in there.
The chuck jaws are not parallel with the spindle, or the spindle isn't parallel with the bed?
http://www.mini-lathe.com/Mini_lathe/Chucks/chucks.htm
http://www.mini-lathe.com/Mini_lathe/Tuning/tuning.htm
Somewhere on that site is a description of using a tool post grinder to true up the chuck jaw surfaces, but I can't find it now.
Sorry, that was confusing. It seems as though the spindle is parallel with the bed, it's just that the jaws are not parallel with the chuck, so it sends the piece off in one direction (the runout gets worse the further down the piece you go). I've read about grinding jaws, but this thing was supposedly ground well within spec from the start. I might contact Shars and see what's up.
I need to read up on chip breaking, because these strands were 3+ feet long. At one point it got wrapped around the lead screw :(
This lathe stuff is fun. It helps if you use the right tool though, doh! I wanted to machine a pocket for the MCPCB but instead of using a boring bar I used a 1/4" right facing/turning tool, and I didn't realize there wasn't enough relief so the tool cut into the piece along with the carbide tip. Oh well. I switched to a boring bar this morning and cleaned up the inside.
I need to see if I can adjust this wedge type QCTP. I can't even use the spindle-facing attachment point because the handle hits the tool holder before it clamps down...
Here it is fully open...
I'm thinking about buying some cheap digital calipers and mounting them up to use as a DRO. Keeping track of the marks on the wheels is a pain in the ass, and it would be nice to have a metric readout.
Most tools I use are 3/8'' HSS square that you can gring into all sorts of weird and wonderful shapes to do the type of thing your doing. Heres a couple but theres lots more.
I recommend that you learn to use the wheels. It's not that hard and any cheap DRO that you buy will be prone to goof up when you get coolant/oil/chips all over it.
JohnnyC want to learn ALOT about machining?
Go find the youtube channel tubalcain…he has hundreds of helpful videos on machining
MACHINE SHOP TIPS tubalcain playlist #1 thru #100
MACHINE SHOP TIPS tubalcain playlist #101 thru #200
If you get good at machining…can I make a request…I need a convoy S2 pill/space all in one…threaded from front to back so I can solder the triple XP-G2 noctigon on there.
I can get .875 (21mm) or 1” copper round stock from these guys, not sure if the best or not on price…but I really would like an all-in-one pill for that kind of build
Posted up some pictures and info on my first (very basic) project - First use of lathe - P60 pill for L2T.
Awesome, thanks! I'm sure I'll kill way too much time watching those.
Ha, maybe a few years from now. It will probably be a while until I figure out threading. I don't plan to ever be half as good as the other members on here with a lathe, I just want to be able to turn a thing or two from time to time :)
tubalcain teaches you how to cut threads
Amongst a few hundred other things
Sad that such skill, expertise, and artistry is slowly fading away here in America…sure, there will always be machinists…but now they beep beep boop push a button and the machine does it…the “old school” way of manually slinging chips is rapidly fading
I thought the same thing about Eagle PCB as well…and after a few short video tutorials…I whipped up a board, is it professional…heck no, but if I can learn how, I am sure you can learn it 100x faster
I just wished my brother was still in Texas, he lives in Cody WY now…he has been a machinist for 20+ years, ran everything from old mechanical lathes/mills to CNC…not sure if he burned out on it…he drives a daggum bigrig now…sheesh
(me…I went the electronics route )
Ever see this site?
http://www.mini-lathe.com/Default.htm
A 7x16 for under a grand…what whaaaaaat?
http://www.micromark.com/MICROLUX-7x16-MINI-LATHE,9615.html
Oh, ChicagoX gave me a big binder with printouts from mini-lathe.com, really helpful.
The downside with this 9x20 is that it doesn't have a variable speed motor, have to keep changing belts. That one linked looks nice, I like that you can zero the handwheels.
do you have a DTI and holder or even just a dial indicator you can mount up somewhere? First order of business would be to test the spindle bore and register (flat bit that the bottom of the chuck butts up against) for runout. Should be less than a thou. Then take the back plate off the chuck and mount that on the spindle, then do the same for runout. It may be that either the chuck register or the back plate face is not completely flat or perpendicular to the spindle.
It doesn’t hurt to dial in the chuck to the lathe its going to be used on anyway. So, with the backplate off the chuck, put a nice fat o-ring on the spindle, thread the back plate on backwards so that it compresses the o-ring. This will force the backplate onto the threads so that it’s as true as you can get it. Take a light facing cut on the backplate register so there’s fresh metal all round. Then turn the back plate around (remove the o-ring) and re-indicate the face. You can then take a light facing cut of the backplate face. Then attach the chuck to the backplate and test for run out with a known good round and true piece of material (I think you can buy pieces for this exact purpose). Or if you’re a cheap ass like me, a inkjet printer rod. You can then do a 2 collar test to make sure your tailstock is aligned properly.
I very much doubt that your jaws need grinding, that’s something that needs to be done on old or heavily used chucks (like my 80+ yr old 3 jaw) that have bell mouthed or tapered jaws.
If you don’t have one already, get a 1in (and poss. 2in) and a set of telescoping bore gauges. For the work we do, they’re indispensable.
+1
+1
[/quote]
Maybe I forgot to say, but the runout on the adapter plate is good, along with the face of the chuck. Are you sure that same logic applies for Chinese chucks? ;)
My lathe was made in China. The chuck that came with it is pretty darn good. I'm going to look for the video where Tubalcain (mrpete222 on Youtube) checks his chuck jaws for wear.
Here it is.
Check your jaws with a feeler gauge like he does in the video and let us know what you find out. Notice that you MUST use a straight piece of work. I recommend drill rod.
Awesome thanks. I'll check it out. Speedy opened a place only 30 minutes from me, wahoo!
