Finally built my DDH-D2GC!
Convoy M21A/DDH-D2GC
Lots of Cooling Fins!
6 Thanks
Potato masher
The newest version, DDH-M4C has a USB-C opening on the opposite side of the switch.
And this is the XBY 32mm buck + FET driver with 22.5w reverse charging.
Just FYI :grinning_face:
8 Thanks
I thought about it but I wanted to run a 6v SFP55(It’s sorta round) the 3v version is square.
I’m going to use the dual 21700 tube(only comes in Black) and a driver I designed for the SFY55.
It should be able to push the SFP55 to maximum Lumens(or burn it up we shall see).
My next DDH host will be the F8A
Cool!
The red switch with ring is very beautiful
It looks even better in person and it’s RGB so the color can be changed.
In this picture it’s Blue:
Nice
Those a very impressive numbers. Have you measured amps draw? I’d like to know how much amps that single LED is pulling to get those numbers.
Not yet. I have a clamp and will measure it soon(hopefully)
That’s one heck of a light. I’m gonna need like 3 or 7 of those drivers. :winking_face_with_tongue:
I suspect the click of the switch is soo satisfying
Unfortunately the click of the button is the 1 thing I’m having trouble with.
Without the button retaining ring the button is nice and clicky.
As soon as I add the retaining ring the clickiness disappears.
I haven’t had much time to play with it.
Oh that’s good, the D2GC has a 22m driver right? Quite disapointing, but 32mm is plenty of real estate for a high power DC-DC driver.
Yes, it’s 22mm like the D4v2
@Power On with a fully charged Samsung 30T - 4,100 Lumens @14.37A( the highest I saw before pressing the Hold button)
It’s pretty tricky getting Amps and Lumens at the same time.
I used a piece of 18ga Wire and my UT210E.
Thanks for testing and posting. 14 amps from a 3V LED is impressive… at least it is to me. I’ve been gone too long, maybe numbers like this are the norm now days.
I tested the light with a VTC6A last night and got 200 more lumens at power on:
Got any EVE 50PL on hand? I’m really curious what that led pulls straight from the battery although it can’t be much more due to high Vf.
Unfortunately I don’t have any tabless cells yet.
They’re on the list but keep getting bumped for other things
Try to screw slowly the ring until you feel the button is not satisfying and give me a feedback. probably the ring is too tight. Have you put rubber under the cover?
