Although I’m planning to use my L2 in the 1S configuration, I’m curious to know whether any the boost driver you’re developing could provide 12V with either one or two cells.
The new boost driver supports Narsil and Bistro OTSM
the thing is they are right now limited to one LVP level, so if configured to 1S they will have 2.8V LVP also if you put in 2 cells so then you got to use protected ones
Does the efficiency of the torch change when running the boost driver from 2S rather than 1S?
I’m guessing that the higher input voltage might mean less current drawn from the two cells, leading to a better runtime than if they were in 2P configuration, but I really don’t understand the electronics.
Hi Lexel,
I would like to order one 17mm Narsil driver (that is FET+7135 with pads for e-switch, right?), for the Sofirn triple C8 host. As the host features leds on the switch board, does the driver come with pads for them (like in the Q8)?
The new 17mm with LDO added has pads where you can solder a resistor, but no dedicated pad for one, if you cut the trace for R1 Vcc you can use that resistor pad foran indicator LED resistor
If you have parts available I’d be interested in a 2s srk sized driver. Double switch tactical with ‘remembered’ level or if not possible turbo at power up and fully populated 7135s for use in my aborted contest entry. 70°C step down. Basically, something similar to the srk I got from you that’s in my chimera but with the most recent firmware and hardware improvements.
edit: other sizes are possible but bigger is better for thermal transfer (larger contact area) since this light will be housed in a 4 1/2” od 1/4” thick 12” aluminum tube that will have plenty of mass and surface area to dissipate heat.
You always need a resistor. The little smd leds will blow up with 4.2v and too high current.
Lexel will add a tiny smd resistor to the pcb then you attach the wire to the other end, but they are fragile and can easily break. I usually add a beefier resistor inline on the wire from the driver to switch pcb.
Some switch pcb have a resistor built in. So check for that.
