the new versions of 30mm, 21mm S42 and bigger have a populated Ind/Vcc LED resistor pad
I preinstall there 33k as a moderate value, can be made brighter soldering a 2. 0603 resistor on top
Yeah, I noticed the new design. In the 30mm driver pictured above, is the indicator led resistor the one to the right and below the positive indicator pad? It looks like it has the letter M on the resistor.
Or is it the 2 blank pads to the right and above the positive indicator pad?
There are two Pads for indicator LED
One used with 3 channel 1S or 2 channel 2S with LVP with MCU output
The other for 2S 3 channel with 5V for the switch LED
I’d like to buy 2 x 30mm 2S drivers with NarsilM for my L6s.
Reading through this thread, I see there’s an option for moon mode when first powered on with the rear switch - that’s my preference.
I have also soon 4 LED side switches and special for the L6 e-switch compatible 8x rainbow tail LED boards that have a voltage regulator and so the bleeder can be chosen with a very high value for low parasitic drain
Finally got mine installed over the weekend.
Access to Moonlight/Turbo/Last-Mode-Memory - check
Stepless Ramping - check
Locate-me mode, when off - check
and USB charging - check!
Thanks Lexel, for providing these nice S42 drivers.
the quad optics can be modified to get em resting on the LEDs, you have to remove some material near the lefs to get em deeper in the head
then you have to put a spacer between glass and TIR on the outer ring
22mm Bistro HD OTSM Attiny25V one with steel spring and one without.
both with silicone wire…. But not sure on the length, Ill take your advice on this one.
Moonlight + Heat monitor + Ramping UI + Memory in one…. and Moonlight + Heat monitor + 4 Mode + Memory in the other. If possible.
Lexel, I was responding to a post on a S42 thread about the Narsil driver and a question occurred to me.
On the Narsil Driver, one of the switch LED’s is being used to indicate MCU signals, but the other switch LED is unused. Would it be possible to wire the second switch LED to someplace on the remaining USB charging board to lit when there’s current flowing to the battery for charging, and to turn off when the current drops? This would essentially provide the “charge complete” feature that the original S42 offered without need for the old (now partially disconnected) MCU.
