Yeah I added all the new stuff,
not merging TA drivers with the established buck
and the new boost which will come later as the regulators are sold out
Got my drivers. Thanks Lexel! I didn’t know they would come without the 7135s on them. Which 7135s should I get? The 350ma or the 380ma?
Thanks again!
The driver has one AMC in 2S operation, it is single sided
this allows indicator LED output and prevents XHP70.2 to glow in standby
Is this for the L6 and/or MF01? Are they still triple channel? I’m confused by this.
Lexel:
Robbygee3:
Thanks again!
this allows indicator LED output and prevents XHP70.2 to glow in standbyIs this for the L6 and/or MF01? Are they still triple channel? I’m confused by this.
L6 and MF01 2S TA are for now build as FET+1 AMC7135
I can build them triple channel, but had reports of main LEDs lightly glimming plus then no indicator LEd MCU Outpus possible because of LVP divider
Robbygee3:
Thanks again!
So, I don’t need to add any 7135s? There’s 9 empty spots on the L6 driver and 15 empty spots on the MF01.
Lexel:
Robbygee3:
Thanks again!
this allows indicator LED output and prevents XHP70.2 to glow in standbySo, I don’t need to add any 7135s? There’s 9 empty spots on the L6 driver and 15 empty spots on the MF01.
No, you are good to go. It’s already been tested by Lexel.
When it comes to 2S lights, they produce 8.4 volts and the 7135 is only rated to something like 6v or 7v. In most cases (if you can buy the raven claw version) they can handle 8.4 volts with no issues, usually. Every now and then a 7135 will not be able to handle the higher voltage and cause strange things like leak voltage and the emitter might glow when turned off.
To combat this, and maybe because he can’t get the raven claw 7135 any more, Lexel has changed the design. It is more like the Q8 driver, FET + 1. I think you lose a bit of efficiency, but it’s more reliable. No one complains on the Q8! Lol
Ok, great. I’ve just seen pictures of the MF01 driver with the 15- 7135s on it, and mine looked a bit naked.
Thanks guys.
JasonWW:
Thanks guys.
In fact, Texas_Ace (his driver design) is also building drivers for the Haikelite MT09R without the 7135 chips as they are 6v and 12v.
I wonder if the lack of good 7135 chips is the reason for the change?
Robbygee3:
JasonWW:
Thanks guys.
The change to a 2. channel MOSFET in TA design comes from high currents creating voltage spikes that can kill the AMCs in 3x XHP70 builds
Its easy to replace one AMC, also the leaking is so low with one the LEd does not glow
Mod’s all done in my H03 and it all works great! My only complaint is I seem to be getting some coil whine/PWM noise on mid levels? Is this a known issue? Are there any ways to prevent this?
PWM frequency should be around 20kHz, there is no coil that could whine, on the buck or boost drivers this is a common thing
bmengineer:
Okay, so what could I be hearing? It’s silent on turbo and the lower levels, but around 50% to 80% (very rough guesses) it’s squealing at me.
Lexel:
bmengineer:
the current is switched by the FET mostly at this level, its a drop from 0 to open FET
Maybe the driver is a bit loose or the cables cause it
Ok thanks, I’ll take another look at it and make sure everything’s in there right. Also, someone on Reddit pointed out that there’s no LDO on my sample, is that supposed to be empty?
LDO is only needed for 2S versions, as well as 2 resistors as voltage divider
1S needs only the diode and chip reads voltage from supply
That didn’t seem to fix it. I posted an image on Reddit and some users suggested the BR and zener might have been connected by mistake?
The driver looks fine
Lexel:
bmengineer:
There was discussion few years ago about this phenomena,I think conclusion was it was mainly because of tiny sparks(arcs) created at spring-battery contacts because of PWM, similar to arcs created in mechanical switch after turn on/off. It would be interesting to see this with slow motion camera.
You think the spring couple be the culprit?
