Fireflies E07 preview
Where did you pull these numbers from? To me these are completely baseless and is misleading for those unaware. I suspect turbo is designed to last 30s on the E07 as is. By adding 40g to the head as I suggested, it will last much longer. Adding 40g to the head of the E07 is almost doubling the mass and should be close to 100+ g and will allow turbo runtime to increase much more than 3 sec while brightness decreases much slower.
I just tested my C8F again and at 2 minutes, it only dropped to 2,680 lumens but for some reason abruptly dropped from 2,670 lumens to 70 lumens at 2.5 minutes (timed step down or defect?). However, the head was still comfortably warm at 2.5 min.
Because E07 has 7 emitters, the current will be spread among the emitter so each emitter would be pushed less than a 4 or 3 emitter light under the same setup. However, this doesn’t change the fact that a 30T battery is capable of pumping much more power (watts) than a 30Q in a C8F.
I understand some people like yourself do not need the light to be practical and do not care about having stable output for longer periods. I also understand some never use their lights over a couple hundred lumens but there are much smaller lights for that. However, there are also some people who prefer a Turbo that last much longer than the 20sec on the D4. I actually use my lights for work purposes illuminating large interior spaces and I see this light to have the potential to replace my TC20, which can maintain about 1,000-1,200 lumens and is the current best for its size. I also own 3 D4 and only use them as toy lights because I can’t find any practical application for them.
FF already have a 4 LED light, which is the PL47, which is basically a D4 headlamp, that I already have two on order. I don’t see a point for FF to make another quad given there’s already the D4, D4S, EC65, TO46R, and TO50R that fulfills all needs from hotrod toy to practical light.
A few examples of fins done right to increase the surface area :
Eagle Eye X6 // Skilhunt H03 // 4Sevens maelstrom X7 // Sunwayman V10R (secure and removable deep-pocket-carry-clip done right)
No need to make a bigger head when the surface area of thermal exchange is already bigger with fins done properly.
My favorite is the TR-J20. The massive finned head on this thing can probably handle 10k+ lumens continuous if using an efficient driver and leds.
I also love the massive fins on the Olight SR90. Hoping they release an updated version with modern LEDs and drivers.
Did you configure the Emisar’s for max temperature?
I agree with SKV89 that increasing the head mass will improve the turbo runtime, and it’s really useful. I don’t know how much it’ll improve but comparing my D4 and D4S, both set to max temp, the difference is indeed big. Further, for me it won’t make a difference in EDC so better safe than sorry.
E07 look well but for me 25 degree is not option. I have no where to use. it would be nice to have a spare option of 15 degree.
also samsung leds!
By milling deep fins, the thermal transfer by convection is increased while the mass is reduced. :wink:
I never configured the temp but it gets burning hot. Max temp is probably set higher than on my D4s.
I would sacrifice some mass for additional fins. Although I would love to see 1+ min turbo, having higher sustained low-mid power level is more useful for me than extending turbo runtime. However, they can easily add back the mass by thickening the shelf and walls.
YES! The trj20 thing. Thats what i was thinking. In copper.
Hi guys. I want to buy batteries in advance.
What do you advise?
Shockli 21700 4550mAh, Samsung INR 21700-40T (preferably)
I don’t know where did you get the 30s from. Myself I did a quick calculation based on assumption that turbo time is directly proportional to mass and inversely proportional to number of emitters. As I noted this method has flaws but should arrive in the ballpark of being correct.
You’re very wrong. I care about regulation and I care a lot about practicality. But I can live without the former and the latter is precisely the reason why I don’t like adding mass for mere improvement to turbo time.
My use case is to have just a couple of hundred lumens sustained. But I blast turbo to either get a better view of some area or to see farther. Usually 10 seconds is enough. Sometimes it’s not. But those cases are definitely not worth a weight increase.
“Maintain” means efficiency and heat shedding capabilities. Not weight. And 1200 lm is not turbo, it’s just a medium mode.
7 emitters give good efficiency, though with a different driver that could be better. On the head-shedding side the head is barely finned and quite small.
Effectively, I don’t see this light as a sustenance queen. I’m far from being certain about that though.
11.11 might be a good time to buy batteries.
Depends on the needs
  • Samsung INR 21700-30T - for max output
  • Liitokala Lii-40A - good cell for a good price
  • Samsung INR 21700-40T - very good cell, a bit better than Lii-40A
  • Shockli 21700 4550mAh - very good cell, not very expensive
  • Sanyo NCR21700A - very good high-capacity cell, though I would hesitate to use it frequently with a hot-rod like that
Myself, I have Lii-40A already (and no light to use them in :wink: ). If I didn’t have them, my pick would be Shockli 21700 4550mAh for runtime and 30T for output.
I like to add that the Sofirn 21700 4.000mAh seems to be quite comparable to the Samsung 40T at a very decent price. Maybe it will be even cheaper on the 11/11 sale. For maximum runtime I recommend the Samsung 50E cell with 5.000mAh.
thank you very much for the tips.
I said I suspect they will design turbo to last 30s, which is based on the ROT66. To me the calculations you claim to have made completely don’t make any sense. I don’t see how increasing the the mass in the head by at least 50% will only increase turbo runtime by 3s. If FF really designed Turbo to last only 12.5s as you calculated, that would turn away a good number of purchases. There were plenty of comments laughing at the 10s turbo on the Nitecore TM10K. Also the D4 and PL47 already fill the short blast turbo toy category so it would be a bad business decision to have the E07 turbo last only 12.5s and with probably equally poor sustained output. E.g., the D4 drops to 250lumens at 60s and below 200lumens a bit after and subsequently oscillating around 2xx lumens the whole way (depending whether tail standing or handheld).
As I stated earlier, if I had to choose, I prefer more fins over more mass. But preferably and optimally, mass should be added as fins where possible to increase heat dissipation; but to maintain the size of the light it seems not easy to increase fins. However just adding mass alone will extend low and mid power runtimes also, not just turbo as I showed in my posts above. I would much rather the light can handle a decent output for 30 minutes than 15 minutes.
You are restating to me exactly what I already explained in my posts above.
Adding mass extends steady output runtime and slows temperature gain at all output levels. I normally use my flashlights for 20 minutes or so at a time so if a flashlight like the TC20 can maintain 1,000 lumens for 30 minutes, then I say it can maintain 1,000 lumens for my typical use cases and probably most uses cases.
Right now, the 138g of the E07 is lighter than every single other light of its size class yet it is the most powerful one. Your own post here shows a list of other lights and they are all heavier. I have never heard of anyone complaining about any of those lights are heavy. Adding 40g to the head of this light is hardly noticeable and it will still be lighter than the majority of those less powerful lights in your list. I suspect most potential customers would prefer the very noticeable performance/runtime advantages from this hardly noticeable increase in weight. I already provided information from my own testing in my posts above how much added mass can benefit maintaining steady output and reducing rate of temperature rise.
I bought 4 ROT66, 2 PL47, but I will probably buy only 1 E07 if it is only good for 12.5s turbo, and probably equally poor low-mid level thermal/output performance. However, if the E07 has at least the same output/thermal performance of the D4S and preferably the C8F and TC20, I will probably buy a couple. My friends who use flashlights for work will surely ask me to order some for them if it turns out more than just another D4 toy.
These lights are so small, why not add 80g of mass instead and make turbo run times acceptable? It's not as if this light is going to break anyone's hand holding it from being too heavy.
I bought some Sanyo NCR21700A 5000mah Tesla batteries. They perform better than the 50E and 48G. You can read about it here.
Look at these comparison graphs, it can maintain voltage better than the other cells for the entire duration of the battery capacity.
I bought the Sanyo NCR21700A from “Vapcell Dennis”. The price is so low I will not post it here. Give him a PM on BLF. Also, you might want to order the button top version because the standard version is recessed and will not work with most chargers. The button top version adds some resistance so you don’t get the full 15A continuous rating.
If you want max turbo output, then get the 4000mah VTC6A or 40T. From my testing on the C8F 21700 and TK01 (both not as powerful as this light), I see literally no difference in measured peak turbo output between the VTC6A, 40T, and the 3000mah 30T and even if there is on a light like the E07, it will be hardly noticeable base on my experience testing numerous 18650 high output lights with different cells.
Weight wise, I think most people will have no problem and it would only cost literally a few pennies more to make. With battery included, it will still be lighter than most lights in that list. Even a Shockli 26650 weighs 96.8g. However, it might not be easy to increase that much mass without increasing size or going with copper and I doubt FF will want to make those kinds of changes. Personally I won’t mind the light being a bit bigger especially if fins can be added or deepened (it’s currently smaller than the D4S in every dimension) but I think many people would want it as compact as possible so adding at least 40g (to the head) would be decent.
