A capacity test, in this case, is literally the worst way. They are similar in capacity. If you mean resistance that’s hard to measure for just anyone.
klrman measured and weighed it and it’s out of spec for a real 40T. The bottom indention, while a lot batteries do have this or something like it, is very consistent. It doesn’t look anything like this and there is no reference for a 30T or 40T to have it.
I could ship you mine, are you in BC? ...or, I could just pull the wrapper off and see if anything is underneath. Is it dangerous to remove a wrapper from a non protected cell?
How accurate is the Opus BT-C 3100 internal resistance test? Also at which voltage do I have to measure that? Mine says 40mOhms @3.6V. Charging it up right now.
Just tested IR on the 40T from ff with my SM8124A and it reads 12.
I just inserted a freshly charged 30Q in my E07 and my lumintop ODF30C is slightly brighter on turbo than my E07 and both my rot66 are significantly brighter than the E07. My ROT66 both have XPL-HI 5000k and my EO7 has XPL-HI 6500K. I have done no anduril adjustments for turbo yet, but my understanding is that when the light is on and I double click, it will go to max brightness in turbo with the factory settings?
Dale, would you happen to know if these leds look like XPL-Hi to you? They look like them to me, but my E07 seems to be about 4000 lumens bright max running a charged 30Q button top.
I had the same problem . I couldn’t get more than a couple thousand lumens out of mine . I contacted Jack , and sent a video of it using a TA meter . He is replacing it . He has been very responsive and helpful .
Output for me was close to same with 30Q , 40T , 30T .
