I noticed the same thing. Using the “40T” from Fireflies, my light is much, MUCH brighter than if I run it on Sony VTC5A from Mountain Electronics. The VTC5A is rated for a much higher max discharge than the 12A Lishen.
Is it perhaps a bit of a stretch to assume the 40T Fireflies shipped are rewrapped Lishen given that they seem to perform so well? Maybe they’re rewrapped something else. Lishen aren’t the only cells that have the ring in the bottom.
They can pulse higher than 30Q. Doesnt make it a good 21700 cell. Dont make excuses for FF. Call them out on this they should admit their mistake regardless of intention. Samsung cells dont magically get longer, heavier, with different casing. Sorry.
Ok, let’s clear something up on the Twisty E07…. if you have a short to the negative lead the MCU will be bypassed and you’ll have direct drive. If you have a short to the positive then you are in a dire situation and there will be smoke and melted bits inside the light. It’s really that simple. A short to positive is magic smoke, a short to negative is a bypassed driver or twisty flashlight.
Hahaha yeah! Screw up one wire and you get a twisty light. Screw up the other wire and you get a pipe bomb! :smiling_imp:
Now that everyone has had the pep talk… aren’t you all excited to open up your light and start desoldering leads to fix the thermal compound on the star?
This is the first light I’ve ever opened up that used 18 gauge wire for the driver. That wire is THICK and becomes VERY rigid once solder gets into it. I needed long-nose pliers to bend it vertical so I could get the star out. I applaud Fireflies for seeking to reduce resistance by using thick wire, but it is a new experience working with it.
I'd love to order a legit 40T but nowhere to do that without paying an arm and a leg for just one cell shipped to Canada from within Canada or from the US. Think the cheapest option in Canada with shipping is $32.00 for one battery.
My second E07 arrived today. First was in yellow, but I wasn’t a fan of the sharp edges on the fins or the gritty anodizing. Second one is in clear. Feels great in the hand and looks great.
Guess I’ll also have to open this one up to service the back of the star.
Include the measurements you took and observations of the battery itself as evidence. He needs to verify this himself too if he is not yet aware of it.
I want to know what to choose so I need some numbers. XP-L HI 5000K and SST20 5000K.
I need lumens, candela and current draw with same battery and same measuring equipment if possibble. Can somebody make these?
