4x Nichia 219B SW45K 4500K R9080 CRI95 Max 2500lumens
4x SST20 4000K NW Max 2500lumens CRI95
4x SST20 6500K CW CRI66 Max 3500lumens
4x CREE XPL HI V3 CW 6500K Max 5000lumens
4x CREE XPL HI V3 NW 5000K Max 5000lumens
Product Description:
Made of 6063 aluminum alloy
Body color: champagne color and Black color
HAIII Anodising Surface Finish
1x 21700 / 18650
15 degree angle TRI lens
98% AR coating glass lens
Digital current regulation on lower brightness
IPX8 waterproof , underwater 2 meters
with Aux leds —Cyan blue ; with switch leds blue (7-click to control aux leds)
With Strong magnet on the tail part
Size: 89mm x 28mmx24mm body
Weight: 78gram
Accessories: standby O rings ; Flashlight clip; 18650 to 21700 Transfer device; Gift box
How to operate the light? (Anduril UI by Toykeeper)
PL47 uses free software distributed under the terms of the GNU Public License version 3
This might be the first light I’ve seen where that style of clip is appropriate. It allows the head of the light to stick up out of a pocket, or above a strap as shown in the picture.
Fireflies, you might want to add a link to the PL47’s page at your store, to help people find it.
a 21700 is awesome. I have one without a home. Ready to purchase this; deciding on a color but I like the black look.
Have you seen the headband that is available to buy as an extra? It’s a lot of headband for just a few bucks; looks like it could support a 2x26650 headtorch! Make it happen Jack, I’ve got a big forehead, I can take it!
Toykeeper, I received the ROT66 XP-L HI with Anduril and I like how the ramp stop at the maximum regulated level. Is the PL-47 setup that way too and do you know about how many lumens at top of ramp? I like easy access to a max sustainable level for practical use. Thanks.
The default config goes above the highest regulated level, because the driver is a FET+3 design. The +3 part only goes up to about 400 lumens, which makes for a pretty low ceiling. But for easy access, you can still loosen/tighten the tailcap to return to that level, or I think the default stepped ramp will have a level which hits that exactly. It should be step 5 of 7.
If I understand correctly, the supply of 219B emitters is running low, so it’s less a matter of whether there will be a 219C version and more a matter of how long the 219B supply will last.
