MSRP: $80
Sale is as is!
Battery not included!
he Fireflies PL47G2 is a compact, right-angle EDC flashlight and headlamp built around a single 21700 battery, quad TIR optics, and the customizable Anduril user interface.
Key Specifications
• Battery Compatibility: 1x unprotected 21700 Li-ion battery; supports optional short 22430 tubes.
• Output & Emitters: Advertised up to 2,800–4,500 lumens depending on the emitter choice (such as Luminus SST20, Nichia 219B/519A, or Cree XP-L HI) and optics. Tested peak output varies by LED and measurement timing.
• Optics & Beam: Quad TIR lens (available in frosted/floodier or narrower 10°–30° configurations depending on batch/variant) with AR-coated glass.
• Body & Durability: Typically 6061 aluminum alloy (about 78 g without battery, ~88–89 mm long, ~28 mm head), with limited runs in raw brass or copper (~150 g). Rated IPX8 / IP68 waterproof.
Features & Performance
• User Interface: Runs Anduril (or Anduril 2 on later iterations) with smooth and stepped ramping, direct moonlight, battery/temperature checks, strobe/utility modes, and electronic lockout.
• Auxiliary Lighting & Tailcap: Features auxiliary LEDs (such as ice-blue aux LEDs and switch backlighting) and a magnetic tailcap.
• Thermal Behavior: High turbo outputs step down quickly due to compact mass and heat buildup, settling into lower sustained output levels for longer runtimes.
