Received a Wurkkos FC11C and tested for Flicker… All but the Low mode have very constant power to the LED… I then DeDomed, because I just prefer that Tint. In this reflector, the DeDome produces an excellent beam, no ragged hotspot artifacts.
The FC11C is quite long and heavy, 111 grams w battery and clip… as heavy as a D3AA plus a TS10:
imo the FC11C is too big and heavy for (my) lightweight slacks pocket carry (with no belt). Would be fine in jeans w a belt maybe, imo it is more suitable for a jacket pocket, backpack, or kept in the house, on a table or counter top… (I just like small lights)
Physical lockout works to prevent accidental activation, although the button is quite flat and not overly prone to being pressed by mistake inside a pocket.
The UI is easy for a muggle… and the USB charging makes it suitable as a Granny light… The main 3 modes have Last Mode Memory, but the 1 lumen moonlight can not be memorized (turbo neither).
The magnetic tail makes it easy to secure the light on top of a refrigerator. But there is no indicator light, that would help locate the light in the dark, and the switch button is not easy to find by feel.
Here is the DeDomed Beam:
Decided to install a 20mm 30° Pebbled Tir, here is the beam… its quite nice…
These are the parts I removed when installing the Tir:
That clear O ring normally sits between the glass and bezel.
The light still has the black O ring (not pictured), that originally fits between the glass and the reflector, now it is between the bezel and optic… so still water resistant… One advantage of using the Tir, is now there is no glass to break. (Tir wont break if the light is dropped.)
