I have been meaning to mod a few of my older flashlights, but i do not know where to start.
Here is what I have to work with:
Xeno E03 XML T6
I would like to mod this one first, as it was the cheapest and i wont miss it if i mess up Overall I prefer neutral white emiters (4500-5500K), what would you recomend for this little light? currently it does around 500LM on a 14500 cell, and 200lm on a AA eneloop.
Fenix TK41 XML ?? (cool white 800LM version)
I was thinking an XPL-HI for throw? Will it work in this reflector? Where can i get one on copper for this light?
EagleTac D25c Ti XML2 U2
As i am not really interested in max output in this light, and usually leave it in my car, i wanted to try a 90+ CRI emitter for this one, but something that is not too warm, any recommendations?
Other lights that i have:
-Olight S30R III (maybe a mod to neutral as well? :laughing:
-Olight X7 Marauder
-Zebralight H600w
-Armytek Wizzard Pro v3 XHP50 USB Warm
I have did some basic soldering before, but i do not know if i would be able to swap just the emitter on the board, and might as well update to copper while I am at it, so i would also be thankfull for anyone who would point me in the right direction on where to buy these emitters pre soldered on a copper board (14mm for xeno and eagletac, havent oppened the fenix yet).
You’ll still need to file it down to fit 14mm but it’s already mounted on the board at least. They use to have a 219c 5700k if 4000k is too warm for you but it’s no longer there.
Thanks! So its currently not possible to get the 219C 5700k anywhere? Where can i purchase the cree easywhite that zebralight is currently using on some of their lights?
I doubt that emitter is mounted on DTP (it would say so if it were). It’d make a big difference, plus it’s probably around 70-75 CRI
Sanding down the board you can just use a file or sandpaper and run the board through all the way around or use a rotary sanding tool. For the high cri Cree emitters like new Zebralights, I don’t think it’s available yet unless you want a 8 week lead time and can spare enough for 500 emitters. This is as close as I can find: XPLBWT-00-0000-000UU640H Cree LED | Mouser
