Is there any Chinese shop that sells cheap flashlight rings (like the one below) for Convoy S, C and M series? (I guess it is the same size for all)
http://i58.tinypic.com/2sa02lh.jpg
Even if you found one in the correct diameter, it could push the tailcap back and possibly cause the tailcap to lockout with some lights, maybe all.
Here is an Aliexpress shop with lanyard rings, but they are a bit pricey. $6/each. I’m sure they would make a deal for a larger quantity.
Also crazy expensive
4$
2.85$/unit for 4+ units
+1
they are made for xeno lights and there is a slot on the light for the ring to sit . it won't work on any other lights .
farka f8v5
My Nitefighter, Crelant, and a few others have similar rings and are all the same diameter.
they are made for xeno lights and there is a slot on the light for the ring to sit . it won’t work on any other lights .
farka f8v5,you can try fobuy youself.
:bigsmile:
