You need a build from @gchart.
Thanks, after looking at @gchart 's posts I came across this, but itās still unclear where the source is for this light.
Unpinned !
Looks to be it, thank you!
Iām trying to get ādynamicā mode group changes running with bistro.
Meaning that it changes between mode_group 1 and 2 with a triple tap
For that I removed the whole bit after
if (fast_presses > 0x0f)
And added
if (fast_presses > 5) { // Config mode
_delay_s(); // wait for user to stop fast-pressing button
fast_presses = 0; // exit this mode after one use
mode_idx = 0;
if (modegroup == 0) {
modegroup = 1;
else {
modegroup = 0;
save_state();
restore_state();
output = modes[mode_idx];
actual_level = output;
But it doesnāt seem to switch the group on the fly.
It wont switch between mode_group 1 and 2
Has anyone done something similiar before?
I know that lucidrv for example does the Turbo-Shortcut so it must be possible
Hello, on an S2+ with 4 modes 0.1% -3% -30% -100%.
Doesnāt this type have a tiny type micro controller and I canāt change it to 12 modes?
Or does it have a hidden function to change the mode.
I would like to have strobe.
I would like to have something like this 0.1% -3% -30% -100% -Strobe or another mode that includes it.
Thank you.
Many Convoy drivers donāt use the ATtiny microcontroller anymore, but a different controller that cannot be updated.
Ok I thought so, it would be nice if they were all mode 12 but locked in 4 and choose each one the mode.
I didnāt know anything about this and it was the first one I saw I just noticed it was with the sst40.
I still donāt have it, but I know about electrical and programming if I open it I would see it right away but I guess if it warns that they are 4 modes it will have a cheap ic that just does that.
It is a theory, without opening it I do not know.
Even if it matches the pibes could be soldered an atiny I have several models of 8 pins in smd.
Thanks for the heads up nor will I open it will be as you say.
Hi all, Itās been eternity plus 5 months since Iāve flashed any drivers and now I cant remember. Iām working on something very basic. I have the old STAR firmware loaded into Atmel Studio 7.0.
EDIT: Nevermind the first part, I figured that out.
Also I cant remember. When I flash a 7135 driver can I just flash it with OFF time memory code, or does it require different hardware on the driver?
Offtime memory requires an OTC (capacitor) on pin 2. The ānoinitā version, star noinit, uses a different method and does not require the OTC. Iād suggest trying the noinit version.
If youāre actually using the AVRISP mkII to flash, (or ATMEL ICE) you can flash without AVR-tools / AVRDude, flashing directly from Atmel Studio, but be aware that these devices do not supply Vcc to the target MCU like the USBASP programmer does. You need to supply 2.8V-5V to the board with a liion or other source in order to flash it.
Are there any ādouble clickā examples for clicky firmware?
I only know 3 clicky firmwares with this functionality and the source code isnāt available for any of them.
Which one do you mean exactly? There are multiple examples which have an action associated with double click / tap.
Lucidrv(2)/Guppy3drv/the L4P LD-A4/B4
Iām planning to build a bunch of TA 17mm FET+6+1.
I basically just want to add double tap Turbo to tripledown or add 3channel support and double tap turbo to Biscotti
Crescendo has double tap, triple tap and quad tap options too and its firmware is avaible
Sweet! Iāll check it out!
Thanks Luna!
This is an incredible initiative! As a flashlight enthusiast, Iāve always found it challenging to source reliable firmware. Having them centralized in one repository is a game-changer. Iāve bookmarked your links and will definitely contribute if I come across any firmwares worth sharing. The README is also pretty comprehensive, especially for newcomers. Kudos for putting this together!
Hey all,
I am going to use Toykeepers STAR one mode firmware on a 7135 type driver that has the zener diode on it for a 6v setup. I cant remember how this effects the LVP values.
For example if I wanted a 5.5v target.
