I have this Flashlight and key holder in my trailer. Looks like it is designed for maybe a Maglite? What modern led light would fit?
A wide-head 2-cell diving light would probably fit.
Iβd recommend to check inner diameter and order what you like with head diameter greater than the hole and tube smaller than the hole. Probably no need to go through both holes.
Looks like a Maglite ML25LT. Specs for that one are as follows.
Barrel Diameter
1.2 in. 30.48 mmHead Diameter
1.7 in. 43.18 mm
Could also be a 2cell D one though, in which case it is way larger:
Barrel Diameter
1 9/16 in. 39.67 mmHead Diameter
2.25 in. 57 mm
