Flashlight turn on with out a tail cap.
I was shocked to see my trustfire x6 turned on with the tail cap. I was installing fresh new batteries after i put in the 3 cell it turn on without the tailcap.
Unless theres a short somewhere, that would be shocking indeed. Can you take a video of this happening?
your 3rd cell is not insulated/the wrapper is damaged
Hi your correct the wrapper on the third cell is cut open.Well this cost any type of damaged to my x6?
No.
It’s best not to have that cell in your light until you at minimum re-wrap it.
The torn area has already produced a short. And depending on the depth of the cut, it may begin to leak. A leaking battery will damage the light, particularly, if it gets down into the driver area.
Batteries are cheap and easy to change, compared to having to replace a driver.
If you have any doubts as to the success of a re-wrap just replace it
Thanks for the advice.
