Flood lantern/working light with stand, adjustable brightness and CCT
Hi All,
I am looking for an alternative to my right angle headlamp for close range work, I find myself too often try to set my headlamp on surfaces to find the correct angle and brightness for the job at hand. I also want something with more brightness and possible CCT choices.
Main features are:
  • brightness control, or at least 5-6 levels
  • flood and spot
  • built-in charging with 21700 or similar
  • CCT control
  • stand/hook/magnet to adapt to different working conditions
  • weight < 500g
So far the Fenix CL27R or the Nitecore NWL20 seem to check most of these but are a bit pricey. Are there other alternatives I should look at, maybe from more niche brands? I would probably avoid any mule headlamp such as DW4 just because I will still have the problem of not having a proper stand.
Edit: I am located in Europe, just in case some seller don’t ship here
Any suggestion is appreciated!
This may suit- it fulfils a lot of your requirements. Wuben F5 - The Best Rechargeable LED Camping & Tent Light?
Thanks! That seems to be pretty good but it has an integrated battery and the stand seems to be flimsy. Have you tried it yourself?
Fenix CL27R All The Way !
Yes, I’ve got one.
One of the review sites has pulled one apart - so it’s possible to replace the battery. From memory, they measured the CRI and it was above 90 too. It’s got a tripod socket- so you could fit a mini tripod on the base of it- if the inbuilt flip out stand doesn’t work for you? It can be used as a powerbank, comes with a carabiner hook for hanging it up, has the built in magnet etc.
It’s in a lower price bracket than some of the others mentioned.
That’s how I got to the Fenix by reading that thread!
Yes the Fenix looks really cool, just twice the price as the other choices such as Sofirn LT1/S or the Astrolux® WL01 also looks interesting and quite cheap.
Probably they aren’t in the same exact category… !? But you probably know better… !?
I chose Fenix every day of the week and twice on Sunday… !
There’s no doubt that the rotary dials of the Fenix are really classy!
There are many ways to find what product fits better and why… ! I prefer my way… !
I can’t find it now, and it’s possibly discontinued, but there was a machine lamp style light with adjustable gooseneck, which took 3 or 4 18650 cells and had a magnetic base…
At one point Vinh was selling a souped up version, I can’t for the life of me find any record of it on the web, does anyone remember this light?
Edit: just needed a bit more digging on Google, found it! Weltool M3!
Thanks for looking into that! Unfortunately I really prefer with internal charging. It’s definitely a strange looking lamp but cool concept.
