Note: This charger and battery was kindly provided by Folomov http://www.folomov.com/en/about/?24.html for me to review.
Introduction
I received the Folomov Key Charger in a beautiful packaging, plain and simple. Folomov took special care to wrap the plastic case in bubble wrap to protect it from damage during shipping, which was admittedly a nice touch.
I must admit that I had my doubts about a charger the size of a wireless car remote. I’ve always used Nitecore chargers to charge my lithium ion batteries and recently changed to a Liitokala dual bay. However, these chargers are typically more bulky, and I looked forward to having a small charger that could still do the job, especially when I need to travel light – this Folomov Key Charger proved its worth, and I must say I haven’t left home without it in the past month that I’ve been testing it for!
What do I love about it?
- Small
- Light
- Batteries don’t get warm
- Clear indication of battery level via the 4 bright LEDs
- Can be used to charge/power other appliances i.e. powerbank (see use case below)
Folomov also kindly provided a 3400mAh battery for me to test this on.
This is how it looks like, with all its cable unraveled. The docking bay takes the positive end of the battery while the circular removable bit takes the negative end. Both are magnetic, which helps the battery stay in place while charging. Without the battery, the negative end snaps right in, flush with the body of the charger.
For size comparison, from left: 14500 battery, Folomov Key Charger, Olight S1A baton. Small and lightweight, perfect for charging on the go.
Specs
These specs are provided by the manufacturer, and can be found here: http://www.folomov.com/en/content/?136.html
Dimensions:
Weight: 31g / 1.09oz
Length: 66mm / 2.60in
Width: 37mm / 1.46in
Thickness: 17mm / 0.67in
MSRP
$16.99 USD on Amazon
Compatible Batteries
Compatible with 3.6V/3.7V Li-ion rechargeable batteries above 2000mAh in capacity (18650, 20700, 21700
Current
Max charge current: 2A
Max discharge current: 2A
Other features
*Automatically activate 0V batteries
*Overcharge and over-discharge protection
*Short circuit protection
*Reverse polarity protection
*Battery level indicator
Charging Indicator & battery capacity
1 blinking LED: below 25%
1 solid LED, 1 blinking: 25% – 49%
2 solid LEDs, 1 blinking: 50% – 74%
3 solid LEDs,1 blinking: 74% – 99%
4 solid LEDs: 100%
Keyring Attachment
Yes
Charging up my powerbank using the 18650 battery. As this had 1 solid LED and 1 blinking, the battery capacity was between 25% – 49%.
Since this battery had built in charging capabilities, you can also charge it up using any Micro USB cable. Sweet!
How I’ve been carrying and using it
I attach it to a keyring, which then hangs together with my keys and pill fobs. It’s so compact I sometimes forget I have it with me.
I’ve also used it to charge up my sister’s iPhone 8. It went from 85% to full charge in about 20 minutes. Nifty little gadget.
Attached my cute little USB flood light, and I get a floody light source, ready for outdoor picnics.
What I think can be improved on
- Would be nice if it can charge more battery types
- A way for us to select the charging current (so we can select a lower current, thereby extending the battery life)
- The charging head (the one that plugs into the power source) should align with the body of the charger, and not jut out
- Change orientation of keyring attachment hole so the keyring can lie flat (or even better, provide the keyring)
Conclusion
Since I’m not a fan of buying lights that are MicroUSB rechargeable (because I think it affects its waterproofing capability), I need a charger that I can bring with me on the road or for trips. This tiny little Key Charger fits my needs, and will be part of my EDC. The powerbank feature is a nice bonus and that means I don’t have to carry that bulky Uber powerbank anymore.
If you’d like to read a more technical review of the battery complete with charts and graphs, HKJ has done a fantastic job of that here: https://budgetlightforum.com/t/-/53232
