steel_1024
(steel_1024)
1
FOLOMOV’s new portable charger
Design concept is very good, easy to carry around
You can understand everything by looking at the picture!
Transparent plastic box packaging
back
side
The other side
Original battery
Positive
Back
Can be carried on the keychain
Open the wiring, pay attention to the positive pole on the body
Connect 2A load first, test USB power plug, can provide 5V 2A
The new battery starts charging and the charging current is as high as 1.66A
Automatically control the charging current to 0.74A
Charging is nearing completion, down to 0.37A
finished charging
The charge completion cutoff voltage is 4.22V
Blinking
Charging status light indication
iPhone charging
Detect battery remaining capacity
21700 lithium battery is also suitable
Too lazy to type
Directly charge the battery
Thanks for watching
fluke
(fluke)
2
Thanks for the review.
Where can I get one of those load testers with multiple usb connecotrs?
steel_1024
(steel_1024)
3
d_t_a
(d_t_a)
4
HKJ has reviewed several of those.
I think RD Tech’s HD35 would be a good start.
There’s also the DTU-CC01.
And YZXStudio’s ZL1100 (which I consider as one of the more advanced load testers). And then there is also the EBD-USB+ for graphing/saving with a PC…
fluke
(fluke)
5
Thanks.
And where did you get the switchable load?
Not seen one with that many inputs that has fixed resistance.
Pete7874
(Pete7874)
6
I’m only seeing 4 LEDs on this charger, so how can you have 1 blinking LED and 4 solid LEDs (5 total)?
Looks like an interesting charger though.
4.22V after removing from the charger seems a bit on the high side, no?
steel_1024
(steel_1024)
7
I ordered from the same store on Taobao.(China)
They also have an adjustable 25W load
steel_1024
(steel_1024)
8
1. Should be a bug.
2. I think the voltage is a bit high also.
steel_1024
(steel_1024)
9
Edit:
YZXStudio is a true professional design and a better choice.
d_t_a
(d_t_a)
10
(probably off-topic for this thread…)
Is there a ZL1100-equivalent load tester from WEB? Can you point me to a product link or review link? Thanks.
steel_1024
(steel_1024)
11
I spent some time searching for information.
I found YZXStudio to be a truly professional design.
Although it is a bit expensive, it is in a leading position.
Thank you for the review. Folomov KEY Charger is available on Amazon now.
travis
(travis)
13
Seems huge for keychain.
I’d rather just have the Folomov A1 magnetic charger in my pocket.
Pete7874
(Pete7874)
14
The one that HKJ reviewed was under-charging. Has Folomov fixed that issue yet? Not a big problem, I suppose.
