Using a Shockli 5500mAh 26650 at 4.10v, and UT210E amp meter, I got around 17+ Amps on Turbo for the EA01S (4x SST40 5000k).
I’m quite sure that using a higher drain battery like Samsung 30T can get a bit higher (maybe 20 Amps or so?)
Good question, if you are getting 26800 version, you might have to stick to 26800 battery only (to be confirmed with my tube next week). Unfortunately, i don't think BG will be selling standard (26650/21700/18650) tube separately.
26800 tube group buy is for those who already bought EA and FT flashlights.
Well, to build a spacer to fit 26650’s in a 26800 light shouldn’t be so hard - all you need is something to isolate some metal that connects the battery-negative or -positive to the light. Something 3d printed with a 6mm (ca. 6% of the diameter of a hamburger for our U.S. friends) piece of round copper inside would be enough.
freeme, thank you for measuring it for me! I don't want to remove it from the gasket to measure it because it will break into two, so I estimated it with calipers.
inhavent reached out to Banggood, would you be able to do it for me? I only ask as they may respond quicker to you. I would defintely just buy the Kaidoman one, I wonder if 38mm will fit though? I have no experience with "material removal" on glass if I have to manipulate it to fit..
I would like to go the OEM glass route first, and if I don't have any luck I will go with kaidoman.
if Banggood is able to help out, I will buy a few. I could even add it onto another order. I could find something else to buy
