ASTROLUX FT03 Mini NM.1
OSRAM Colored NEW USB-C 18650/ 18350 Flashlight
For reference, this is my order timeline for our Group Buy(1st batch).
Note: speed of delivery varies from country to country.
Group Buy Price: from $29.99!!!
Emitter: OSRAM NM.1
Brightness: 510 lumens
Beam Color: White/ Red/ Orange/ Green(brightest)/ Blue
Body color: Black / Blue / Green
Battery Type: 1* 18650 / 18350
Can't wait for our reply??
FLASH SALE Price: $32.99
Valid till: BGFMSS
WE NEED More SUBSCRIBERS!
www.youtube.com/embed/yn0VdISzIA0
Specification:
| Brand & Model: | Astrolux FT03 MINI |
| Material: | Aluminum alloy |
| Emitter Type: | NM1 |
| Light temperature: | White Red Orange Blue Green |
| Output: | 510 Lumens |
| Distance: | 860 Meters |
| Beam intensity: | 185,000 CD |
| Driver: | Texas Avenger FET Driver with charging |
| Battery: | 1x 18650 (not included) unprotected 18650 recommended, and must use unprotected 18350 battery. |
| USB Rechargeable: | Yes, Type-C (USB-C) Quick Charge |
| Reflector: | High quality smooth reflector |
| Lens: | Glass with anti-reflective coating |
| Body: | Aerospace grade aluminium alloy |
| Button: | Silicone rubber |
| Impact Resistant: | 1.5 Meters |
| Waterproof: | Equivalent to IPX7, do not immerse in liquids |
| Body Color: | Blue / Green / Black |
| Weight: | Approximately 136g without cells |
| Size: | with 18650 tube: 144.8mm* 43.5mm* 25.5 mm (length* head diameter* body diameter) with 18350 tube: 113.7mm* 43.5mm* 25.5 mm (length* head diameter* body diameter) |
| Package included: |
1x Flashlight Head 1x 18650 body tube 1x 18350 body tube 2 x Spare Waterproof O-rings1 x Lanyard 1 x User Manual
Operation UI:
| Operate | Current Status | |
| OFF | ON | |
| Single click | Low | 1. Not at Turbo now: gear cycle (Low - medium1 - medium2 - high, then return to low and continue the cycle to high) |
| 2. At Turbo now, it will: return to the gear before the turbo | ||
| Long press | Moon | Off |
| Double click | Turbo | 1. Not strobe now, will go to: Turbo |
| 2. If strobe now, will go to: Quick flash-SOS - Candle flash (and cycle) | ||
| Triple click | to Strobe | to Strobe |
| Four click | Report voltage | No reaction |
| Five click | 1.If locked state now, will go to: Unlocked | 1.If locked state now, will go to: Unlocked |
| 2. If standby state now, will go to: Lock | 2. If standby state now, will go to: Lock | |
| Six click | Tactical lighting mode (this will be cancelled after power off) |
No reaction |
