Interested in Code for FT03S SFH55.
FT03 code please
Ordered. Thank you freeme
Code for both the SFH and SFT version please!
I just received the SFH version. It measures 160560 candela, 10032 lumens, and 27.0 amps at turbo (using a Lishen LR2170LA). The candela is a bit disappointing but somewhat expected due to the orange peel reflector and the big die size.
How long does the turbo last?
Feeeme can I have coupon and link for sft40 ft03?
Hi Freeme can I get a code for the sfh55 please? I don’t see it listed on BG.
That will be approximately ~800m? May i know at what distance did you take your reading?
Thank you Freeme
Need code for the FT03 SFT40 please. Thanks.
Newbie Sofirn/Astrolux addict here. Been lurking on here for quite a while. Coupon for FT03 SFT40 please?
I’d expect about 50% more candela from the sfh55, even with the OP reflector. Curious what others get
Hi Freeme,
Interested in code for FT03S SFH55 and FT03 SFT40. Thanks.
Also code for FT03 SHF55 please? Can’t make up my mind so both it is…
Thank you.
intrested
1.5 minutes without touching the calibration.
fogofwar:It measures 160560 candela, 10032 lumens, and 27.0 amps at turbo (using a Lishen LR2170LA). The candela is a bit disappointing but somewhat expected due to the orange peel reflector and the big die size.
I take all my measurements at 3m. I have a pretty accurate lux meter and I think it’s fine for candelas up to 1 million at 3m.
