Order placed for Ft03, thanks Freeme!
淘宝网 - 淘!我喜欢
淘宝网 - 亚洲较大的网上交易平台,提供各类服饰、美容、家居、数码、话费/点卡充值… 数亿优质商品,同时提供担保交易(先收货后付款)等安全交易保障服务,并由商家提供退货承诺、破损补寄等消费者保障服务,让你安心享受网上购物乐趣!
My flashlight is not reporting voltage correctly when doing a battery check. It will flash 3.9V for a fully charged 26800 that I measured 4.1V on a multimeter. Is this a known problem with Narsil? Sorry if it had been asked before.
Unfortunately it's a compile time setting - I was going to add a UI config for it, like Anduril 2 does, but by then, Anduril 2 was already out with it and I never thought Narsil would still be shipping - it really shouldn't be, there's no reason why Anduril 2 can't be used.
There are some voltage drop variances, most likely the diode, but I think the MCU itself could introduce variance as well.
I never had any direct contact with Mateminco/Astrolux/BG so wouldn't have been able to give them an updated version anyway. I have no idea where they are getting it from, or if they are attempting to calibrate voltage at least on a batch basis.
Thanks for your explanation
It’ll be worth the wait. I ordered on day one and was surprised I got it the day before Christmas.
Just got the sfh Mateminco version. Extremely bright and throws good as well. Doesn’t throw as far as the 50.2 version but close with a lot more light output.
I updated the MT70 Mini (FT03 equal) SFN55.2 to Anduril 2. Soldered the leads temporarily:
Here's the SFN55.2. Love the tint - I'd estimate ~5200K by eyeball, but smooth, consistent, no tint shifts:
Here’s the SFN55.2. Love the tint - I’d estimate ~5200K by eyeball, but smooth, consistent, no tint shifts:
Will this work?
Is it the same adapter?
It's close but I wouldn't trust it - it doesn't say USBASP 2.0 on it, and the layout of the part locations is different. This is a public board layout design - it should be duplicated identically.
They have one here, left most selection: https://www.aliexpress.com/item/1005001581138352.html?spm=a2g0o.productlist.0.0.2c9f7d2eThr8ZD&algo_pvid=84306383-de93-408d-97b6-a93b84e1a5b2&algo_exp_id=84306383-de93-408d-97b6-a93b84e1a5b2-4&pdp_ext_f=%7B%22sku_id%22%3A%2212000016673143067%22%7D&pdp_pi=-1%3B1.8%3B-1%3BUSD+2.05%400%3BUSD%3Bsearch-mainSearch
Whats up with the MCPCB traces ?
Looks like its a running a series configuration on the split pads? There’s no way this thing uses a boost driver, so what gives?
They cut the trace, not sure why but it came that way.
I see that now. Thanks.
I was thinking that there’s no way this emitter could have dual configuration with 9 chips.
Interested in SFT40 version. Thanks
If this LED it’s so nice - better than SFH55 and SBT90.2? I’ve had MT70 Mini with SBT90.2 in the past, it has nasty tint shift.
It’s worth buying with SFN55.2 from Mateminco on Aliexpress?
It’s close but I wouldn’t trust it - it doesn’t say USBASP 2.0 on it, and the layout of the part locations is different. This is a public board layout design - it should be duplicated identically.
They have one here, left most selection: https://www.aliexpress.com/item/1005001581138352.html?spm=a2g0o.productlist.0.0.2c9f7d2eThr8ZD&algo_pvid=84306383-de93-408d-97b6-a93b84e1a5b2&algo_exp_id=84306383-de93-408d-97b6-a93b84e1a5b2-4&pdp_ext_f=%7B%22sku_id%22%3A%2212000016673143067%22%7D&pdp_pi=–1%3B1.8%3B-1%3BUSD+2.05%400%3BUSD%3Bsearch-mainSearch
In additional to this, I must buy couple of cables like you have?
I see that now. Thanks. I was thinking that there’s no way this emitter could have dual configuration with 9 chips.
Yep, it doesn't. I got a couple of these bare LED's in from Neal and the backside has no separation in the + and - pads. I just think they have a MCPCB not properly designed for this LED, guess it was intended for 12V.
If this LED it’s so nice - better than SFH55 and SBT90.2? I’ve had MT70 Mini with SBT90.2 in the past, it has nasty tint shift. It’s worth buying with SFN55.2 from Mateminco on Aliexpress?
That's weird - I have a few SBT90.2 lights and never saw what I'd consider a a tint shift. XP-G3's, XHP50.2, XHP70.2 all have it, plus can be seen in other LED's. TK had a recent post saying no-dome LED's don't have a tint shift because the dome is the source of the tint shifting, varies based on the optics. Forget where she posted it. It's been my experience the flat LED's don't have a tint shift - XPL-HI, XHP35, SBT90.2, and all these new flat Chinese LED's I've tested so far.
Yes. here's where I bought it: https://www.aliexpress.com/item/32636925245.html?spm=a2g0o.9042311.0.0.2ac54c4dH7VBqx
May want to check the threads that are dedicated to flashing firmware.
Interested in code for FT03S SFH55
Thanks!
HI Freeme
Please consider to re-issue of codes for FT03/FT03s colored filters and tube of FT03s for 26800 battery .
Hello Freeme,
Interested in code for FT03 SFT40. Thanks
