since its using a single emitter the drain shouldnt be a problem for most high drain cells, if u want the most the keeppower 6000mah should be ok if they fit this light, otherwise soshine 5500mah or other similar would provide longest runtimes.
Besides the 30T, the P42A and 40T are also up there. The P42A from an initial full charge lags a bit compared to the 30T and 40T, but for the full discharge, it seems to do better. Mooch review indicates that. 20 amp cells can't compare to these high performers.
As we already saw from the Mateminco MT35mini review, the current draw is around 7 Amps, so I think there will be no benefit from those super high drain 21700s, only reduced runtime.
Here is how Shockli 5500mAh and P42A compare at 7A
My NW order was placed on Feb 21 …. status ‘paid - in process’ from Feb 22 (stayed this way for 33 days)
I just checked again today … I see my order has been canceled.
WTF?
Dunno. My SST-40 mods and Dales' using a similar driver do more amps than 7 amps on high quality cells. Basically with our BLF type of FET drivers, the battery directly effects the amps drawn - there's nothing else there limiting amps except the usual resistance culprits, like LED wire thickness and length, springs, poor FET, etc. Even if you have inefficient wires and springs, the quality of the battery will make a difference.
Unless I'm totally missing something here - this is a standard TA/BLF driver, right? He didn't limit amps some how?
llmatic asked specifically for the highest output/performance, not longest run times. I can show you countless comparisons of cells for FET based drivers in lights. You guys saw my Q8 battery test results, right?
Where's the MT35 Mini review? I'd like to see exactly what's referred to.
So, what makes you think the flashlight is designed for 7 amps, and that using a Soshine 5500 mAh cell vs. a 30T will make no difference? I'm confused - of course I had to translate that to English. It sure looks like a FET based driver to me from the pictures...
What exactly in the review is drawing the conclusion that the light can do no more than 7 amps regardless of cell used?
I only see a CW FT03 in the pictures - no NW FT03.
The guys are refering to the Black & white Shockli cell which is a 5500mah cell & has a continuous discharge current of 20a, more than enough for this light and almost double the runtime of the 30T.
Thanks, but yes I know that - I have Shockli's, as well as many other brands/models of 26650 cells. That's not answering the questions though.
The 20 amp spec is meaningless for this light, but does indicate it's a relatively high resistance, low power cell that a 30T easily beats in this light.
