According to MT35+ specs, their reflector dimension is 124.1mm x 103mm (height) x 26.2mm (LED).
I placed order for 1, Thanks freeme
Interested in price.
Ordered mine. Thanks.
Hoping I will not get blind testing it
Ordered.
Thanks freeme ! :+1:
Please send code. Intreseted in one. Many thanks.
I’m disappointed that its not the first 100 that stated they were interested that get priority when ordering (like the first 500 with the GT)
Instead its the first 100 that place an order that get the benefit of the lowest price…… :person_facepalming:
So there’s really no point in being quick about saying you’re interested, its only to the manufacturers’ advantage to have an idea of how many people are interested.
Not good. Still interested though so pls send me a code.
Hopefully I will see it in time to be with the first 100 because I’m going on holiday tomorrow morning.
Chances are the fist 100 are sold by the time I am back.
Grtz
Nico
Could You give me the coupon code?
Thank You
Grtz
Nico
I would’ve thought the PM would have been sent to the first 100 on the list first, as was done on the GT gb.
Oh well, still ordered a MF04 this morning! I was 91 on the list.
Yep Nico, too broke to participate at the moment. Mother’s day and all that just having passed us by…
When do you think the shorty gonna be ready?
Jason, where do you get this stuff?
Both my friends GT’s are in the 2300-2400 out the front range at 30 seconds, holding well into several minutes. My Thrunite TN42 measured over 2600 out the front, even at 30 seconds for ANSI ratings. My Convoy L2 is making 2360 even with the cells sitting in it for months now.
Those losses you quote are possible, but not realistic.
You need a light box man….
Here are the xhp35-HI tests I looked at:
Ok, another installment of the LED test series, think this is the last of the test I have done so far. Thanks to KawiBoy1428 for donating the LED’s for testing! First up we have the best output test from an undamaged high bin LED. Click any image to see it larger [image] [image] This next test is of a low bin 90cri HD version and the goal with this one was to see if it could handle an FET driver at full power and what the efficiency was like at lower levels. It only looses 11% efficiency a…
LED test / review EN Cree XLamp XHP35 High Intensity XHP35A-H1-0000-0D0BC40E3 XHP35 HI flux E2, ‚tint 3C‘ UPDATE --- 06/23/18 --- raw data added (link) [image] Since the XHP35 is available on the market, it is often used in high power flashlights. With this LED many flashlight manufacturers got more output at same size and battery configuration. In all the time, I didn’t test this LED though. In this review I test one of the highest bin availabe XHP35 High Intensity…
Plus a few other sources here and there. I’m trying to figure out what the xhp35-HI is really capable of.
The part about losses is not so clear. I hear a bunch of confusing stuff. Like most reflectors only being 85% reflective and lenses being 97–98 clear. Texas_Ace says that xhp35-HI seem to suffer higher losses than other leds. It’s all a bit fuzzy in my mind.
By light box, do you mean a lumen measuring device like an integrating sphere? I just recently got a JoshK sphere, but I haven’t messed with it much. I’ve also got one of Texas_Ace’s lumen tubes coming my way, as well.
I’ve measured a few of my lights, but haven’t measured any raw leds.
Based on your experience, what are some realistic losses?
BTW, isn’t the TN42 only pushing 2A? The fact it has that much output just makes me scratch my head. Lol
Well, I resistor modded my TN42 so it wasn’t making 2A anymore.
THE Very Best lens can allow 98% light transmission, that’s the UCLp, very few are that good. The smaller glass UCL allows 99. But regular borofloat has a 10 loss and I’ve seen that on regular polycarbonate as well, literally a measured 11% loss of lumens out the front with a polycarbonate uncoated lens.
There’s really no need to sweat reflector loss as it’s the only way we get an out the front reading anyway, I mean, sure, there’s TIR’s but most of them are only around 80-85% efficient according to Ledil and Carclo and Fraen. Depending on design and emitter you sometimes see higher but not often. And of course unless you’re spending a fortune for top quality aspheric then you’ll also see a ton of losses there.
That said, I am measuring 1.05Mcd from a 124mm reflector with an XP-L HI emitter and that’s with the aforementioned Lexan Polycarbonate lens. Still trying to get Chris to cut a 130mm lens for me, he’s not the greatest at communication… it’ll happen sooner or later but ….
Please put me in for one.
Grtz
Nico
Don’t worry, it won’t sell so fast. Most people already have BLF GT, so the attraction of MF04 can’t be very high.
Releasing product as soon as possible is very important, of course it has to be good and reliable product.
I think the TN42 throws so well partially due to the focusing, with the led flush with the reflector bottom.I am no expert on the subject but I can’t help but think even the GT may have more performance hidden it with the emitter recessed a few millimeters under the reflector rather than flush.
I think your missing the obvious. The shape of the reflector requires the emitter to be in a certain location. How high or low below the emitter the reflector goes is somewhat irrelevant. You can cut the bottom off of a reflector (the top, too) and still get good focus as long as you don’t change the emitter to reflector relationship, the focal point.
Here is picture that might help.
The parabolic shape of the reflector is specifically designed to have the emitter at a certain location. Now because we are using an emitter which has a die size of 2.35mm2 (not a perfect pin point source) not all of the light hits the reflector at a perfect angle. So you can adjust the reflector to emitter height by fractions of a millimeter up and down and get slightly different amounts of focus, but if you move it more than that you definitely will lose the focal point.
Also keep in mind the dispersal pattern or spatial distribution of the emitter. Output is strongest directory in front and tapers off as you get to 90° off center.
As with most things, especially on the internet, everyone you ask has a different answer and the right ones have a lot of leeway.
These new reflector designs we are seeing with the emitter hole open large with no flat area as part of the reflector are supposedly cut off at the plane of the focal point, the centering ring is technically designed to fit the emitter such that the emitter will be flush with the surface of the centering ring and the step on the ring that holds the reflector fits a designed overshoot of the focal point…. by design and by formula this is supposed to be the sweet spot. There are critical factors that make or break the theories, as usual, and whether or not the manufacturer nailed the design parameter is what determines the success rate. Among other things. lol
Ordered!
Interested. I’m late to this.
