interested, amazing deal
All replied.
So xhp is only in cool white and is more bright ok? Iam rigt?
XHP50.2 is brighter than SST40 version.
Code please
Build quality of ST01 is as good as KLARUS, but please take note of ST01 operation before you request for deal.
Some of you might have issue with simpler UI.
Order placed.Thank you!
So what is the real scoop on the lumens, is it 3500 or 4465 ??
3500lm is ST01 official specs, while 4465lm is the value i got from our initial test.
If you have followed our previous group buy threads, our published values can be easily replicated with similar grade power source(battery). ![]()
Please send the code, thanks.
I like it, xhp50.2 under direct drive for its full potential, for this price I suppose can live with the UI, not sure why they didn’t just have ramping/andruil?
If I’m correct the basic operations are:
> Single click ON (memory)
> Single clicks to cycle the levels
> Long press OFF
For lights having “click-through” levels, I suppose this is better than having long press for both ON/OFF…
I actually prefer “click through” levels over hold down/scrolling, and I much prefer single click ON over long press.
I just realized this recently when I sold a light with the same basic operation as ST01 (a Soonfire NS17) I kept a later version that has long press for both ON/OFF thinking it was the better UI, then later thinking it was nice on the earlier version to click ON and just keep clickin’ through the levels, as opposed to any holding down.
May I have the code?
Thanks freeme! Order placed!
I’m interested in two.
Shared.
Nice one.Thanks a lot.Shame neutral xhps50 still not available…
I use Sofirn 21700…is it possible,that it will put our less lumens?
5000mAh 21700 max out at 9.6A according to Funtastic's test. https://budgetlightforum.com/t/-/65623 4000lm is possible if your cell is able to pull 10A with issues.
Could i get a code please
I was wondering if anyone has tried accessing LED module on Astrolux ST01.
CAN THE HEAD BE OPENED SO AS TO CHANGE THE EMITTER?
I WANTED TO SEE THE POSSIBILITY OF PUTTING A CSLNM1 IN THE ST01 TO MAKE IT A SUPER THROWER.
THE ST01 IS VERY VERY BRIGHT AND WITH AN OSRAM LED IT WILL BE A TREAT...
IF ANYONE WHO HAS THE ST01 COULD RESPOND IF ONE CAN DISASSEMBLE THE HEAD FOR CHANGING THE EMITTER LED........
EAGERLY WAITING FOR SOME LIGHT ON THIS.....
