IMALENT MS12 MINI
12*XHP70.2 65000lm Flashlight
Special Price: $3-- (usual $409.95)
Coupon: ND25F
Can't wait for our reply??
Price: $348.46 (usual $409.95)
Coupon: FREEME
Features:
The IMALENT MS12 MINI is a can-sized super bright searching flashlight, utilizes 12 pieces of American CREE XHP70 2nd (3nd) LEDs , which max output of 65,000 lumens and a max beam distance of 1036 meters. The amount of light that the IMALENT MS12MINI flashlight emits is truly remarkable, a wide beam angle and strobe function are quite ideal for search and rescue. This exquisite flashlight is finely made of durable high-strength and oxidation-resistance aluminum.
Featuring six output levels plus a strobe.This LED flashlight is a must-have for your daily life, outdoor activities and repair work.
Specifications:
- Utilizes 12 pieces of American CREE XHP 70.2(70.3) LED, with a lifespan of up to 50,000 hours and a maximum output of 65,000 lumen.
- Built-in high effective rechargeable li-ion battery pack ( includes 4 pieces 21700).
- Size: 149mm (length)*83 mm (head diameter) *56mm (body diameter).
- Net weight:787g(including battery).
- High efficiency constant power circuit will maintain constant brightness.
- Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature.
- Aluminum SMO reflector.
- IP56 standard waterproof (1 meters submersible).
- Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface treatment.
- Tail stand capability.
- 1m impact resistant.
Package included:
- Imalent MS12MINI Flashlight x 1
- Charger
- 4000mAh 21700 Li-ion Battery(battery pack) x 1
- O-rings x 1
- User Manual x 1
Images:
