LUMINTOP GT94X
4* SBT90.2 24000lm 2950m 4*21700 Thrower Searchlight
For reference, this is my order timeline for our Group Buy.
Note: speed of delivery varies from country to country.
My first attempt with 4* brand new button top Samsung 40T from VapeCell supplier
Group Buy Price: from $480 (usual $640)
Freeme's Exclusive Coupon: reply in this thread
Can't wait for our reply??
Price: from $544 (usual $640)
Coupon: FREEME
Specifications:
Emitter: 4x Luminus SBT90.2 LED , mounted on copper DTP MCPCB
Flux: >24,000 lm
Intensity: >2175 kcd (ANSI throw >2950 m)
Firmware: Tom E’s open-source NarsilM v1.3 adapted by Texas_Ace
User interface:
- By default the GT94X is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 28A TURBO mode is also provided.
- A more conventional discrete level MODE-SET UI is available as an alternative. Anyone of 12 pre-defined mode-sets can be selected.
- MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Battery: Four button-top 21700 cellS(4S) or eight cells(4S2P) via the extension tube(excluded).
Unprotected cells are recommended. Cells are not included.
Driver: 12V, Texas Avenger V2
Reflector: 118 mm inner diameter, aluminum, smooth finish
Lens: Glass with anti-reflective coating
Body: Aluminum with Type III hard-coat anodizing
Tripod socket: Standard 1/4 inch threaded (1/4-20 UNC)
Button: Tactile with back-lit rubber boot
Ingress rating: Equivalent to IP65, do not immerse in liquids
Weight: Approximately 2.5 kg without cells
Dimensions: 135 mm Ø head x 239 mm length
GT94X uses free software distributed under the terms of the GNU Public License version 3
GT94X Anduril code from toykeeper/flashlight-firmware
Package included:
1x Lumintop GT94X flashlight
Images:
