Mateminco FT01 (SEP 2022)
SFQ43 1250lm 209m 14500 Lantern Flashlight Group Buy
Group Buy Price: from $30 (usual $39.99)
Freeme's Exclusive Coupon: 1TDNEW
Mateminco FT02 (SEP 2022)
SFN55.2 6160lm 346m 18650 Flashlight Group Buy
Group Buy Price: from $37.46 (usual $49.95)
Freeme's Exclusive Coupon: ITDNEW
Specification:
Product Name: Mateminco FT01 Brand: MATEMINCO LED: SFQ43 Material: Aerospace Grade Aluminum Alloy Mode: Low, Mid, High, Turbo, Strobe Switch Type: Clicky Switch Switch Location: Tail Of The Flashlight Battery: 1 * 14500 Battery (Not included) Max Output: 1250lm Max Beam Distance: 209 Meters Max Beam Intensity: 11000cd Driver: Direct Drive Driver Impact Resistance: 1m Waterproof: IPX6 Weight: 78g Size: 98.5mm * 43.5mm * 22mm(Length * Head Diameter * Body Diameter) |
Product Name: Mateminco FT02 Brand: MATEMINCO LED: SFN55.2 Material: Aerospace Grade Aluminum Alloy Mode: Low, Mid, High, Turbo, Strobe Switch Type: Clicky Switch Switch Location: Tail Of The Flashlight Battery: 1 * 18650 Battery (Not included) Max Output: 6160lm Max Beam Distance: 346 Meters Max Beam Intensity: 30000cd Driver: Direct Drive Driver Impact Resistance: 1m Waterproof: IPX6 Weight: 118g Size: 118.5mm * 51.5mm * 25.6mm(Length * Head Diameter * Body Diameter) |
Operations:
| Action | OFF | ON | |||
| Click | ON | OFF | |||
| 1x Tap | No response | Moon (default) -Low-Mid-High | |||
| 2x Tap | No response | Turbo | |||
| 3x Tap | No response | Strobe | |||
| Memory | None |
Package included:
1x Mateminco FT01 Flashlight
1x diffuser
1x base
1x pocket Clip
2x O-rings
1x instruction manual
1x lanyard
1x Mateminco FT02 Flashlight
1x pocket Clip
2x O-rings
1x lanyard
Images:
