So i got mine yesterday…and so far I have no issues. I got the lh351.
Beam pattern is fine inside, haven’t taken it outside. On a wall there’s no bad artifacts or anything. It seems to be as bright as my fw3a was but I lost it so I can’t directly compare. Anduril works as it should. It definitely gets hot. The holster is nice. The copper looks cool.
It does feel kind of cheap and the body is pretty thin. The tail switch needs improvement. The head threads also need improvement, they’re very thin.
I’ve had absolutely no flickering so far and am using flattop batteries.
Edit - took it outside tonight and it’s plenty bright. Beam pattern is just fine. I’m happy with it. Aux LEDs are pretty cool. The switch is my only real negative so far…wonder if it can be improved with a rubber o-ring like the fw3a…will try in the coming days.
After extended intermittent use I have nothing negative to say about the sand color lh351d I received other than unwanted adhesive used on the bezel. Still. No flicker, good output but obviously lower than emisar xpl hi v3 3a d4 v2 ti in a direct nighttime comparison.
I originally thought the fm1 was a 5 piece assembly. Tailcap, tube, 3 piece head.
wrong
Interesting design choice inviting improvements. I wonder what legoes.
Lookin forward to your report with the switch. I’m not a huge fan of the travel, but at the same time it is kind of nice to not worry about it accidentally triggering.
We are writing to inform you that we have refunded 473.0100 SEK for order 83896690. Your order has resulted in a refund for refund for quality problem . Please allow 48 hours for your refund to be processed back to your original payment method. If it is for credit card payment, it may take up to 7-14 days to show in your account
Mine arrived today (thanks for the GAW, MascaratumB!!)
I’ve only played with it for like 1 minute but it seems to be in good order so far. Bright, connection is good after I tightened it (it did flicker at first), beam pattern is fine in mine (no donut hole, LH351D version). The noisy button is kinda annoying but nothing I can’t live with (or honestly I can probably find that with a new e-switch or something). I’ll give it a good run through tonight when it gets dark.
